Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd June 2004, 10:14 PM   #1
Default PSU ? : Build or Buy?
Ok, so I need to come up with a 12V@7A PSU to run 120mm fans, cold cathode lighting, IR/RF remotes, and other non Audio 12V items. This will be for projectors similar to what some members are doing in the Video forum. So heat is a concern, consequently I think I want to use a switching mode power supply. Please correct me if I'm wrong, as I'm no expert, barely even a novice lol.
My question is this:
Will I be able to build one cheaper than I can buy one surplus from a place like AllElectronics.com ? I can get 12V@7A from them for around 10 bucks. Is it worth my time to build it cheaper, since the quality of the power isn't as crucial as it is for, say, an Amp? Can I actually build it cheaper? I haven't seemed to find transformers very cheap anywhere. But of course I'm fairly new at all this, and even the paper copies of Mouser, Digikey, and Allied catalogs I have are quite a task to go through for me.
Any advice is appreciated.
Faithblinded
Old 4th June 2004, 12:57 AM   #2
bigparsnip's Avatar
for $10 at 7A you would be alot better of just buying the thing as direct coupled switchmode is rather dangerous and best avoided if you can. The other option is to pick an old, cheep computer PSU as you can quite aesily trick these into turning on without being in a computer and they can normaly kick out quite a bit of 12V current.
I want to try and build my own DAC gareth Digital Line Level 3 3rd July 2009 03:20 PM
ZV9 build ingi Pass Labs 8 6th August 2006 02:40 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Page generated in 0.06435 seconds (69.93% PHP - 30.07% MySQL) with 10 queries
