regulation of 78XX and 79XX at low curent
just put together a +/- 15 V supply using 7815 and 7915 regs. Rectified and filtered supply to te regs is ~ 20V. With no load, the neg side runs at ~16.5 V, and the + side closer to 15 V. Noticed that the factory tests at 500 mA, so maybe they need a slight load in order to operate. I only had .25 W resitors available, so I hitched them across the supply legs, giving a load thru each reg. of 100 mA. Seemed to regulate better, but the test period was pretty short due to overloading the resistors. Any opinions. Sorry if it is a dipwad question! Thanks!
may have it figured out
Just talked to someone who knows these things much better than me. He said that many brands of 78XX and 79XX regs need a small current through them to start regulating properly. He often uses a 1K resistor from output to gnd. I guess it doesn't really matter if the regs are actually in-circuit, being used, and flowing current, but it kind of threw me when I checked the voltage with no load.
The NS datasheet (LM7805) quotes line regulation typically 9mV from 5mA-1.5A load, 4mV between 250mA-750mA, so you don't need much loading to settle things down. More noticeable in cmos logic, where quiescent current may be negligible.
317T is similar, in that if you use high value voltage-setting resistors, the zero-load regulation is poor. One fix is to add a led/series resistor which also shows it's on... ;)
