Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st May 2004, 06:05 PM   #1
Default RCA 3626 power transistor from Crown amp
I am trying to find a source of RCA 3626 power transistors to replace dead ones in a Crown DC300A power amp. Alternatively an equivalent would be good - does anyone know where I can get them?
Old 1st June 2004, 03:16 AM   #2
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
Have you called Crown? They have an excellent service and parts dept. If you hit a dead end I might be able to get my hands on a few.
Old 2nd June 2004, 09:48 AM   #3
No, I haven't tried Crown because I can't find the address of the UK agent for Crown - good idea though!
Old 2nd June 2004, 05:05 PM   #4
I have found out that the transistor is actually an RCA 1B05 despite reading 3626 on the can!
Old 3rd June 2004, 08:38 AM   #5
1B05 is a very obslete transistor - recommended replacement is the MJ15024.
But don't mix these with old ones - replace the whole set.
Cheers
Old 3rd June 2004, 08:48 AM   #6
Thanks a lot for the information. What is the problem with mixing the types?
Old 3rd June 2004, 04:02 PM   #7
Two reasons:
Different specifications will mean they don't share the load current evenly, and
If some of the transistors are faulty, then it can be assumed that the resultant surge when this occurred has put undue stress on the remaining units. Therefore thay are more prone to premature failure (meaning the set should be replaced even if the same type is used).
Cheers
Crown amps, transistor replacement (long) Eaulive Solid State 17 17th August 2011 03:28 PM
MIMPS? crown Transistor matching Zero Cool Solid State 0 8th May 2009 10:50 PM
Crown IC 150 power light mummy Solid State 1 8th February 2009 12:27 AM
Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 tyler477 Solid State 1 31st October 2008 05:24 AM
transistor for CROWN amplifier tom31415926 Parts 4 13th November 2007 04:44 AM
Page generated in 0.09157 seconds (74.40% PHP - 25.60% MySQL) with 10 queries
