Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Can you take a look at this schematic?
Old 25th May 2004, 03:34 PM   #1
punchpeanut is offline punchpeanut  United States
punchpeanut's Avatar
Default Can you take a look at this schematic?
Hi, I'm working on a preamp for my computer and have come up with the following. The first section is based on an ESP project so I know that should be good. I then try to bridge the 2 channels and pass the bridged info onto a LT. I used the spreadsheet to get the values of the LT so they should be right, I just want to verify the shematic will work before I try making a PCB.
Thanks!
Old 25th May 2004, 03:39 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
What is it exactly you are trying to do? Why not cut out the first 4 opamps, directly combine the two and go into a vol pot?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 25th May 2004, 03:45 PM   #3
UrSv is offline UrSv  Sweden
UrSv's Avatar
Looks like he wants a preamp, hence the pre out for L&R. After that he sums up both channels, applies his LT and drives an active sub with that output and the L&R with some other amp.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 25th May 2004, 03:54 PM   #4
Exactly UrSv, I am making a decent quality computer preamp. I want use the preamp to drive the LT and also output to a stereo amp for full range and a powered sub I am making through the LT. I thought by including LT in the preamp I wouldn't have to mess with a plate amp I already have, and wouldn't need an external box and powersupply to run the LT.
I don't need source selection since it will only be used for a computer system, just a fancy volume control.
Old 25th May 2004, 09:18 PM   #5
officeboy is offline officeboy  United States
Send a message via MSN to officeboy
Firstly I am by no means a professional, and even calling me an amateur on the subject is probably more credit then I should get. But Iím not clear on what some of these op-amps are doing, and it seems like they could be removed.
The first set seems superfluous since your computer has an op-amp too and you should be getting enough signal to make the volume pots work. Then after you combine channels, why not just go right into the LT?
It would certainly help simplify the circuit anyways..
Old 27th May 2004, 01:25 AM   #6
dmfraser is offline dmfraser  United States
Default Comments
Bridged T filters are unusual. Usually used if you need a response peak or dip. And you can find a better op-amp than the TL072.
Dan Fraser
Old 27th May 2004, 02:11 PM   #7
Ok, it looks like the schematic will work so I'll work on the pcb. I'm trying to make it universal, so in the future if I like it, I can make it into an audio preamp.
How would the rest of you bridge the 2 channels. This is just a way I have seen it done before. Also, I picked a TL072 since it's only a low frequency curcuit. I also have OPA2134's, OPA2604's, NE5532's, etc.
Thanks for the help!
Old 9th June 2004, 02:47 AM   #8
FredM is offline FredM  Europe
Hi -
One thing I notice is that each pre-amp output has a resistor to Gnd.. As these pre-amps are being summed into a virtual Gnd anyway, these pull-downs are not needed.
My advise would be to make the summing resistors equal to the required loading, and set the feedback resistor to give the required gain.
The AC transfer (frequency response) from the pre-amps will (in the present circuit) be determined by C10 || C11 and R26 || R1 - If you have not calculated for the fact that R1 is loading C10||C11 then you will lose LF response.
If you require C10||C11 into 100k, remove R26, and change R1 R2 + R3 to 100k - and do the same for other channel (remove R31).
I wouldnt mind a copy of the gerbers if you do a PCB for this - would be quite a useful board!
Fred.
Old 9th June 2004, 03:06 AM   #9
looking again at the circuit, I dont like what I just suggested! - The problem is that the L and R outputs also become possible (noise) inputs to the summing amplifier... Worse than this, any DC on these outputs would be coupled directly to the input of the summing amp.
I would leave the pull-down resistors (R31 and R26) and connect R1 and R2 via another pair of capacitors directly to the outputs of the op-amps. You could make R1,R2,R3 = 470k, and reduce the additional capacitors to about 470n(total) for the same frequency response.
Again, the response of the L and R outputs will be determined by total loading - but at least any signal injected into these outputs will face attenuation by the C's R's and output impedence of the opamp.
Old 9th June 2004, 03:27 AM   #10
I have edited schematic, and trying to paste it here.. but cant seem to get it to work-- perhaps it takes time
Can you take a look at this schematic?Hide this!Advertise here!
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 02:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 06:12 PM
F3 schematic kenev Pass Labs 2 24th January 2008 04:24 PM
Need Six-pac amp schematic Sarge Tubes / Valves 1 31st July 2004 09:30 PM
Copyright ©1999-2017 diyAudio
