Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd May 2004, 10:14 PM   #1
bryman79's Avatar
Default Audyn Caps - US Source?
Hello,
I am trying to acquire about 4 of either of the following Audyn 4.7uF caps:
1. Audyn Cap Plus - 800V
2. Audyn KP-SN - 100V
Between shipping and export/import taxes, these caps are too expensive to purchase from Europe. Any idea where I can get ahold of some in the US?
Thanks,
Bryan
Old 27th May 2004, 12:01 AM   #2
diyAudio Senior Member
fdegrove's Avatar
Probably no good to you but here goes anyway:
Intertechnik distributors & dealers:
Germany Intertechnik and Open Air Loudspeaker
The Netherlands Speakerland/Speaker & Co
Australia GSO Audio
CAPS, CAPS & MORE CAPS...
Frank
Old 27th May 2004, 10:53 AM   #3
khush is offline khush  United Kingdom
Default Audyn caps
I am virtually sure Audyn caps are simply rebranded SCR (SOLEN)caps which should be available in North America. Try Angela Instruments( www.angela.com ) or Parts Connection.
Good Luck
Khush.
Old 24th June 2004, 03:15 PM   #4
JC Fardo's Avatar
Unless highlly mandatory reasons to stick with Audyn, Mundorf caps are way better reputable
http://www.e-speakers.com/products/mundorf.html
Hope this helps
JC
Old 24th June 2004, 03:23 PM   #5
Taco is offline Taco  Netherlands
Audyn Cap Plus == Mundorf Mcap Supreme
Audyn Kp-Sn == Solen (SCR) Tin Foil cap
are you making a Tony Gee Design ....?
Old 24th June 2004, 04:05 PM   #6
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Yesiree...that is what I heard too.
But Audyn just sounds better than Solen. (The name that is)
Old 24th June 2004, 04:13 PM   #7
uli is offline uli  Austria
Cool error
sorry, but that is not quite correct...
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 24th June 2004, 04:28 PM   #8
You could be right. But if Audyn does not make their own standard polyprops who is making their Plus series?
Solen does not make a "plus" type cap as far as I know.
PS...on a slightly different subject..from the voltage specs it 800V appears as if they parallel 2 normal 400V caps in opposite "polarity" ? or are the parallel caps (by themselves) of better quality than their standard stuff???
or 2 600volts for the 1200volt versions.
Bas
Old 24th June 2004, 04:48 PM   #9
Default series
AFAIK the Mundorf Supreme cap is built that 2 bifilar wound caps
are connected in series so that the inner foils are the nodes and
the outer foils are just connected. So you get 2 20µF caps for one
10µF in your hand.
I have plenty of Audyn+ es and MCap Sups but they are totally
different, both in sound AND mechanical making.
Intertechnik claims a similar procedure for their +es.
Maybe they are made by the same OEM manufacturer but to
different specs. Everybody can have made his own pink
"Vinzenz Gurkenstrudel" caps when he orders enough!
Uli
Old 24th June 2004, 04:55 PM   #10
JC Fardo's Avatar
Aquablue from Antwerp lists Mundorf and Audyn and may be a little cheap on S&H. Not sure though. Ask Benny.
http://www.diyparadiso.com/
JC
source caps for aleph 1.7 freakyone Pass Labs 28 31st March 2009 07:50 PM
M-cap ZN or Audyn KPSN t. Parts 0 15th January 2007 08:44 AM
Audyn-Cap MKP-QS 400V for EAR 834P ??? Raphael1 Analog Line Level 2 1st October 2006 03:02 PM
AUDYN-CAP sale Thomas Swap Meet 13 10th October 2005 12:43 PM
ERO MKC Caps - Source? bryman79 Pass Labs 0 28th April 2004 06:18 PM
Page generated in 0.09828 seconds (88.13% PHP - 11.87% MySQL) with 11 queries
