| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hello,
We got a little bored today, with nothing better to do on a Saturday afternoon, and decided to try making a capacitor from some paper and some tin foil. Using the capacitance formula (taking into account the distance between plates, area, and dialectric constant) I found an A4 sized pair of plates (kitchen foil) and paper dialectric (0.12mm thick, just ordinary A4 paper) should give around 16nF ish. Well we made it, and the best way we could think of testing it was to use it in an RC high pass filter. We tried it and according to the java program on this page the actual capacitance was around 20nF. I think that's quite encouraging and was wondering about the feasibility of actually building some nice usable caps, maybe making some nice cans for them to sit in and using copper foil. It seems these would be ideal for interstage coupling caps in tube circuits (my amp has 100nF here, and a 100pF in the NFB loop) Just a few questions, what effect would it have using oil (and what type of oil to use) like for example Audio Note PIO's. Also is there any way of telling what kind of voltage they would be able to take? This is the main thing I'm scared of with using these. I guess the thickness of the paper would be the main issue here? Maybe the oil helps in PIO's? Cheers for all your help, Steve |
#2 |
I have got to say that this is the ultimate DIY. Making your own components is definately the pinnacle. Congratulations on your success. I can't think of any reason why your scheme using mineral oil would not work. You would have to do some tests to determine the working voltage though.
----------------------------------------------- It's Alive, It's Alive! Kilowattski |
#3 |
![]() Hmmmm, any ideas on how to determine the voltage capabilities of it without resorting to destructive testing? which i dont really fancy to be honest. Thanks, Steve |
#4 |
That is the DIY spirit, but you are not the first one to make them.
My father used to make his own caps in about the same way when I was a child. To be even more cheap, he even reused the foil wrapped around pieces of chocolate.
"Jitter clock: - - indicates product does NOT have this feature" From product spec. of a CD player |
#5 |
Measure the core temperature onder load, then you just read the voltage when the cap is at the max temperature you dare
Just to follow the forum rules about safety...do this with the cap behind something solid and heat resistant!!! Magura
Everything is possible....to do the impossible just takes a little while longer. |
#6 |
So temperature should really be the main issue here then? Is it ok to use dry paper? or is the oil just used to stop the copper tarnishing? and/or change the dialectric constant? Any clues as to what thickness copper foil would be good, though i'm guessing that depends on factors like voltage rating. I also need a source for copper foil or i could just keep on using kitchen foil....![]() Cheers again, Steve |
#7 |
The main purpose of the oil is to increase the heat transfer. The voltage is determined by heat and when the cap sparks over. The foil thickness determines the load the cap can take...I think.
Magura
#8 |
No, I don't think temperature determines the voltage capability
here. Rather it is the type of dielectric and its thickness. Since you are using paper, humidity also enters the equation so I think it would matter alot if you can dry them and then seal them compared to just using them as they are. While temperature is not important, you will probably not use such a capacitor in a place where temperature will be the limiting factor. It seldom is for film capacitors.
#9 |
Hello,
Well the wima's that are in that position in my amp at the moment are fairly small (polystyrene btw) and they aren't noticably hotter than their surroundings to the touch. Are there any hard and fast rules anyone knows of for what thickness paper I would need to use for a given voltage? Steve |
#10 |
http://uk.farnell.com/jsp/catalog/vi...?prodId=187896
Any thoughts as to how well this stuff would work? Steve |
| Thread Tools | |
| Home-made RCA interconnects | flyingtele | Everything Else | 15 | 8th July 2009 09:22 AM |
| home made | tomtt | Everything Else | 3 | 9th March 2007 08:28 PM |
| Home Made Tubes?? has anyone made one, is it possible?? | John Biles | Tubes / Valves | 7 | 11th December 2005 02:29 AM |
| Home made PCB's | demons_wing | Chip Amps | 27 | 17th November 2005 01:12 PM |
| Page generated in 0.19924593 seconds (81.91% PHP - 18.09% MySQL) with 11 queries |
