| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 |
How about Teflon film and copper foil? Check out McMaster Carr. Teflon film is on page 3334, copper foil on page 3435.
Peace, Sanaka
We are sorry for the inconvenience.... |
#22 | |
Now i'm confused. I thought that capacitors diden't get hot at all unless they had high ESR, in wich case they are broken or if too high voltage causes arcing. Can someone please explain?
#23 |
If you are going to use paper, use 'craft' paper and not notebook paper. The 'craft' or brown wrapping paper has less void area and can take higher voltages without sparking over. Cling wrap is not good for high voltages or high values as it melts and is too thin for stability. Use un-metallized mylar from window tinting for a really good dielectric.
If it sounds good... it is good! |
#24 |
diyAudio Moderator Emeritus
Does anyone know if shellac would be a good dielectric?
Cheers, Bas |
#25 | |
#26 | |
Thanks. Bas |
#27 |
i tried the monitor thing and it didnt work, bah
#28 | |
An ideal cap dont get warm.....ideal caps are real hard to come by ![]() The loss have to go somewhere....in this case its heat. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#29 | ||
![]() Steve |
#30 |
Except for valve & class A amps, that are inefficient heaters, and that inefficiency outlet is sound!
Gaz |
| Home-made RCA interconnects | flyingtele | Everything Else | 15 | 8th July 2009 09:22 AM |
| home made | tomtt | Everything Else | 3 | 9th March 2007 08:28 PM |
| Home Made Tubes?? has anyone made one, is it possible?? | John Biles | Tubes / Valves | 7 | 11th December 2005 02:29 AM |
| Home made PCB's | demons_wing | Chip Amps | 27 | 17th November 2005 01:12 PM |
| Page generated in 0.11418 seconds (80.58% PHP - 19.42% MySQL) with 11 queries |
