Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st May 2004, 03:37 PM   #1
Stocker is offline Stocker  United States
Default Both Secondaries for Positive Voltage?
Given a transformer with a center tapped secondary...
Could you take both secondaries and make them give you positive voltage using 3-pin regulators? That is to say, use the "top" secondary as normal, and then use the "bottom" with the center tap as positive, and use a regulator to get a second set of +V out of it?
general idea drawing (sorry about the quality)
/edit: Probably couldn't use them for circuits that were connected at all, but for independent devices...
Jesus loves you.
Old 27th May 2004, 12:29 AM   #2
Default Yes
Yes you can but you forgot the rectifiers and filter capacitors.
Dan Fraser
Old 27th May 2004, 02:43 AM   #3
paulb is offline paulb  Canada
You don't have to have separate grounds for the positive supplies. You can use two full-wave centre-tap rectifiers (two diodes each) to get two positive supplies, then run it to your two regulators.
http://sound.westhost.com/power-supplies.htm#fullwave
Or if ripple isn't a problem, you could use two half-wave rectifiers, one diode each.
Old 27th May 2004, 11:37 AM   #4
Default Re: Yes
those are my magic regulators with infinite PSRR.
that's why the drawing is called a general idea drawing.
I had completely forgot about the ESP page (seen it before) thanks.
Jesus loves you.
One transformer with 4 secondaries or two transformers with dual secondaries Baka Chip Amps 5 28th November 2008 06:39 AM
Positive regulator to produce negative voltage? stef1777 Parts 45 8th February 2008 07:46 AM
LTP w/ positive only supply arnoldc Tubes / Valves 10 24th May 2007 02:32 PM
Small voltage deviation at positive and negative rail 2Bak Chip Amps 1 14th December 2003 06:42 PM
Page generated in 0.06783 seconds (75.62% PHP - 24.38% MySQL) with 11 queries
