Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th May 2004, 10:34 PM   #1
Default Heat Sink for Dummy Load
I just purchased a number of Vishay/Dale 50W Aluminum Power Resistors to build a dummy load device that will permit me to feed my amp's speaker output into a Direct In device without frying the transformer in my tube amp.
I'm using a schematic posted on the AikenAmps.com web site which implements a switchable 4/8/16-ohm dummy load device by using a 3-2ay toggle switch to tap into different points in a circuit of the aforementioned resistors. The 4-ohm option taps in at a point that uses 2 8-ohm 50W resistors in parallel (not sure why he does this instead of using a single 4-ohm, but who am I to second guess -- I'm taking this on absolute complete total faith since I am an electronics newbie). The 8-ohm option taps in upstream, adding a 4-ohm resistor in series to give a total 8 ohms of resistance and the 16-ohm option adds yet another 8-ohm resistor in series.
So we're talking about a total of three 8-ohm resistors and one 4-ohm resistor, each rated at 50W. These resistors have to be mounted on some sort of heat sink, but I have absolutely no clue as to how to determine what is an appropriate heat-sink to use. In a footnote to his schematic Rnadall Aiken says "All resistors must be well heat-sinked. If the unit is built in a metal enclosure, the enclosure can usually be used as the heat sink." That would be wonderful, if I could do this, but how do I know how big to make it and what is a suitable material (I'm assuming some kind of aluminum would be good). I could also use a separate heat sink inside the enclosure, but again, how big? If I make it thicker can I make it smaller? Can anyone give me some idea about how to answer these questions.
Thanks very much
Old 25th May 2004, 06:23 AM   #2
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
What's the output power of the amp? If the amp is say, 100W then you just need a heatsink that can dissapate 100W max. You probably won't really dissapate 100W constantly unless it's something like an RF amp, but it's always good to overbuild, things run cooler that way. ApexJr has some cool tubular type heatsinks for a resonable price and they're pretty efficient.
Old 25th May 2004, 06:28 AM   #3
Proud Union Member
imix500's Avatar
Oh, btw, he probably uses 2 4ohm resistors instead of 1 8ohm because many amps can provide more wattage at lower impedances, so u have the ability to dissapate 100W with 2 4ohm 50W resistors. You could just use a 100W 4ohm resistor instead, but 2 50W's will probably get rid of the heat faster- more surface area.
Old 25th May 2004, 10:04 PM   #4
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Here is what I use
4 ohm resistors and an option to choose between a total of 4 or 8 ohm load.
\Jens
Old 25th May 2004, 10:11 PM   #5
hmm pic didn't show up
Old 26th May 2004, 09:52 PM   #6
Brian Donaldson's Avatar
I just dropped them in a large glass of water. They'll never exceed 100 Deg c while there is water there.
Old 27th May 2004, 12:58 AM   #7
Proud Union Member
imix500's Avatar
True, but then there's corrosion, electrolysis and knocking the glass of water to worry about.
Old 27th May 2004, 02:04 AM   #8
But then again, this is setup is used for 2 hours 4 times a year. Then dried off and thrown back in my scrap box. Works for me and didn't take away 6 hours and 30 bucks from my habbit.
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
8 ohm dummy load andrewe1 Parts 43 9th May 2011 05:44 AM
Tri Dummy Load raudio1969 Parts 0 25th February 2009 01:14 AM
dummy load reddish75 Solid State 72 3rd April 2008 01:15 AM
Dummy - load JensRasmussen Solid State 24 23rd February 2007 01:04 PM
Page generated in 0.09440 seconds (78.00% PHP - 22.00% MySQL) with 11 queries
