| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
What is your favorite multimeter for measurements?
Let's make something special |
#2 |
Simple answer here is dirt cheap unless you need something expensive.
#3 |
Tank you very much! A very good way!
#4 |
i would look on ebay (if thats an option for you). i got a really nice meter (retailed for around $600-$700 new), for about $60 shipped. it was in excellent condition, but missing manual and a lead. its worked great for me.
#5 |
The Tenma brand has lots of ok meters that do a lot for cheap. They are not the most accurate but they do give you a lot for the dollar. Some less expensive meters even have L and C ranges that are great for crossovers. Most all have diode and some have Hfe ranges.
If it sounds good... it is good! |
#6 |
Why are Fluke multimeters so much more expensive? Are they that much more accurate.
I'm also in the market, since my old micronta radio shack multimeter has come up MIA. I'd like something that gives as much bang for the buck, while remaining accurate. What other brands besides Fluke are known for quality and reliability in multimeters? Do I really have to spend close to 100 bucks to get a real nice unit? |
#7 |
Well, I can safely say that a good meter is a valuable tool when you're working on electronics. Especially projects.
For me, I use a Wavetek 330B, which is the same as a Beckman 3030B I believe. It is one of the older true RMS multimeters that was calibrated for professional use. Mine was used in the industry for telephone systems calibration, so it had to be calibrated every year. The meter, at it's original price, was about $400-$500CDN. Mine came with case, manual, warranty card, two sets of probes, and a carrying strap. I got very lucky with this, I think I payed $30.00 for the kit. As far as meters go, I like this one more than any Fluke I've used. Many people will argue that, however, I am happy with this Wavetek. Either way, before I got this nice meter, I was using a $10.00 cheapie but it was still actually a good meter. It was close enough for normal measurements, had an hfe measurement, and was built with relative solidity. You can get away with cheap meters in many cases, since price only really indicates name and accuracy, and in many cases, the loading property of the meter inputs, which you don't need to worry about in most measurements anyway.
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#8 | |
a not-too-expensive one costs, and you can measure two parameters simultaneously, which often comes in handy. It depends, though, if you have a scope or not. The dirt-cheap DMMs usually don't have any smaller AC range than 200V, so without a scope you might want some way to measure small AC voltages, but it is a bad substitute for a scope. |
#9 | |
Since the post asked about a favorite meter, mine is the Fluke 189. A little expensive, but very very nice. The average, min, max functions are wonderful, and the backlight has made it easy to troubleshoot things in the dark! I like the fluke 87's. They're a good meter also. I've used a bunch of cheap meters, and am not as happy with them, as the flukes. I own a few, but never use them, except for when the flukes are being used else where. I also own a Tenma LCR meter, and have been happy with it for checking caps and inductors. It's not the most accurate unit out there, but hard to beat at under $200. -Dan
-With a bad amp, everything sounds the same. It takes a good amp to tell the difference between true "Artists" and the rest of the "Performers". |
#10 | |
| Multimeter??????? | genmin | Equipment & Tools | 4 | 22nd January 2009 11:30 PM |
| WTB: Multimeter | bjackson | Swap Meet | 0 | 4th October 2005 12:10 PM |
| multimeter | Dj BASS AMP | Solid State | 2 | 29th March 2003 03:56 PM |
| Page generated in 0.10758 seconds (87.07% PHP - 12.93% MySQL) with 10 queries |
