Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th June 2004, 11:51 AM   #11
Devil_H@ck's Avatar
Send a message via ICQ to Devil_H@ck Send a message via AIM to Devil_H@ck Send a message via MSN to Devil_H@ck
Ok, I'll try that. Why is it that it can't turn off? Is it because the "high" current is keeping the transistor open?
Website: http://members.lycos.nl/anthonyvh
Old 6th June 2004, 09:29 PM   #12
amb is offline amb  United States
amb's Avatar
Are you sure you're using a simple (rather than a latching-type relay)? Also, since the input voltage is high (9-12V) and the transistor will turn on at 0.6V or so, you might want to change the 100K ohm resistor to a much lower value (something like 1K ohm, so that it forms a voltage divider with the other 10K resistor to drop the input voltage.
-Ti
Old 6th June 2004, 10:15 PM   #13
Devil_H@ck's Avatar
-Ti
It's a simple relay, I've used them at least 5 times before and they are just plain, normal relays. Nice ones too .
The input voltage is 12V. I'll try changing both resistors, but would there be any difference? Zero volt is zero volt, the problem isn't turning on, it's turning off. Even if the trigger voltage were 200 volts, once there isn't any signal at the trigger input, it's 0 volts, no matter what. Right?
I'll go find myself a darlington tomorrow & then try changing resistors if it still doesn't work .
Old 6th June 2004, 10:26 PM   #14
HDTVman is offline HDTVman  United States
Do you know that the base is at 0 volts? Have you measured it? The lower value resistor from base to grd will insure that the base gets pulled to grd even if there is a small amount of leakage in the transistor and remember, caps take time to discharge. Oh ya. (Have you tried the darlington yet? oops I didn't check the time stamp. sorry)
BZ
What ever makes the tunes flow
Old 7th June 2004, 03:22 PM   #15
Devil_H@ck's Avatar
I got 2 BC517s today, according to the storekeeper they are 1A darlingtons. I wanted BC317s, but he didn't have those and BC517 seems to resemble it close enough .
I'll try it tonight.
* Edit:
Ok, I looked the thing it up:
High current (max. 500 mA)
Low voltage (max. 30 V)
Very high DC current gain (min. 30000)
Should be fine.
Old 7th June 2004, 05:08 PM   #16
Devil_H@ck's Avatar
Ok, it works perfect! Thanks Elso!
Hm, well, almost. There's one weird malfunction kind of thing, but it isn't that important. When I switch the relay on & then off and then pull the power chord so that there isn't any power left, the relay closes for a very short time. Not that this only happens when it's in the off state & the power chord is removed from the power supply, when turn it on/off it works just fine. What could be the reason of this?
Old 7th June 2004, 06:54 PM   #17
amb's Avatar
Are you still using the 100K resistors or did you already change them to 1K?
-Ti
Old 7th June 2004, 08:46 PM   #18
Devil_H@ck's Avatar
Ah, yes, that's probably the problem. Let's see if I get it correctly:
- The relay turns on, the 47nF cap charges
- The relay turns off, the 47nF cap starts to discharge very slowly through the 100k resistor
- The power is removed, the 47nF cap tries to keep the voltage it was fed by at the base of the darlington, thus turning it on. In turn the relay turns on and drains all the power left in the supply's caps.
Hm, actually, rereading it, it seems wrong, since the cap would do the same when I just turn off the relay, right? So, please, tell me, why is it that it turns back on for a short time (untill the supply's caps are empty)?
Old 8th June 2004, 10:40 PM   #19
FredM is offline FredM  Europe
Hi - Lets look at the theory - the transistor will turn off when the voltage on its base is less than Vbe (about 1.4V with a darlington) -
Provided the EN signals are all below (0.6V+Vbe), the time taken for the 100n b-gnd capacitor to discharge will be negligable - the voltage on this capacitor will not charge to more than Vbe anyway (it will be clamped) so it only needs to discharge a small amount for the transistor to turn off. with t=rc, 100n*100k=0.01 (10ms) but I would expect the time to be more like 500us given that rapid discharge occurs first, and that only a few mV drop in Vbe would be required.
I can see no mechanism for the transistor to be turned-on briefly as the supply drops - except if some spurious signals are coming from the EN inputs.
Old 9th June 2004, 02:54 PM   #20
Devil_H@ck's Avatar
Hm, ok then. It doesn't really matter, because it only happens when the power plug is pulled. The relay is used to conduct the AC to the torriods in an amp, so there won't be any more AC to conduct.
But thanks for the explanation, I always forget about the transistor voltage drops.
any simple circuits I can add to a dac? Tristanc1 Tubes / Valves 5 17th March 2009 08:14 PM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 12:50 PM
Simple check to see if mosfet are blown or ok? Optical Solid State 3 14th October 2004 07:58 AM
check my simple circuit svokke Solid State 5 25th March 2004 06:19 PM
Really simple preamp, could someone check it ? 00940 Solid State 19 12th September 2003 05:30 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
