op amp distortion - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th May 2004, 07:06 PM   #1
zahlm is offline zahlm  Spain
Question op amp distortion
there is a thing I don't understand while I look the datasheets
why do the non inverting configurations have more THD distortion than inverting config?
Thank, Zahlm
Old 15th May 2004, 06:46 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
What happens with the input in non-inverting mode? Both + and - inputs are lifted up and down in phase with the music. This creates distortion. It has to do with "common mode rejection ratio".
In inverting mode the inputs are rather still, they are very close to ground all the time!
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 15th May 2004, 12:09 PM   #3
Circlotron's Avatar
In inverting mode (if the input impedance of the opamp were infinite) the signal at the junction of the input resistor and the feedback resistor (the summing junction) is a *perfect* representation of the difference between the input signal and the output signal, and it is this signal that is fed into the opamp.
In the non-inverting method, the feedback signal is fed into the opamp (-) input and generally passes through at least one emitter follower before it gets to the (internal) summing junction. This means that the feedback signal is *not* a perfect representation of the output signal but it has been corrupted somewhat by passing through this emitter follower and whatever else it might find on it's way.
Something worthwhile for the GainClone crowd to consider too.
Old 15th May 2004, 07:45 PM   #4
Thank you very much, that's what I need to know
Zahlm
How to get the less distortion with BJT? dododio Solid State 24 6th September 2008 09:55 AM
Neo 8 distortion? studiotech Multi-Way 4 17th April 2005 05:22 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
HELP - Hum and distortion rampage101 Chip Amps 6 14th April 2004 11:44 PM
Copyright ©1999-2017 diyAudio
