To measure current you need to 'break' into a circuit. That is, you disconnect some part of the circuit and enter in your meter. Current through -- Voltage across, remember that and you will know how to measure. The number on the meter will be the amount of current flowing from your + lead to your - lead.
-chris
-chris
Matttcattt said:How can I measure current (DC) with an LCD meter?
I would guess that I would mesure the voltage drop over a seres resistor, but I have no idea how to implement this.
Any links, circuits or advice appreciated.
Does this meter have a 'current' scale? If yes, you can 'break' into the circuit as described above, that is you put the meter into the line where you want to measure the current. If the meter only has 'voltage' mode, you need a shunt resistor in the line, and measure the drop across the resistor. You want to keep the resistor as small as possible to avoid changing the circuit by the measurement process.
Jan Didden
djQUAN said:you still haven't mentioned what current are you trying to measure.
high voltage? AC? DC? how many amperes? how much allowable voltage drop? what is the measurement range of the LCD module?
This is for in car use.
12v DC
>100A
Dont know...
I dont have a particular module in mind.
HBarske said:This seems to be a classical 3,5 digit dvm, which measures +/- 199,9 millivolts without any additional circuitry.
Yes
If you find out I'd like to know. I want to monitor charging and usage of current on a boat, and 100A fsd would be about right (for now). The problem is the shunt resistor for that current. RS Components do some shunts for 200mV dmms, but not 100A ones. A Hall-Effect transducer could be used, but this is not without problems.
http://www.allegromicro.com/sf/0752/#sample_request
i would use a piece of copper cable.
These people make some big shunts... very nice stuff at that for monitoring all types of battery banks and inverter systems. This link has one such product.
http://www.xantrex.com/support/docserve.asp?id=72
I think you need a pretty decent volt meter as the shunts are 500A~200mV. I think that maybe if I was looking for my boat, it might be a B-U-Y instead of a D-I-Y.
The other option, just monitor the voltage. It's not an unreasonable correlation to the battery condition. 13 volts is good, 12V is bad. 11V means you need jumper cables.
- Design & Build
- Parts
- Measuring current with an LCD meter
