Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th May 2004, 11:50 AM   #1
jamesjung21's Avatar
Question PIC Static Sensitivity
Hi guys,
I just have a quick question, before I construct a kit.
Are 16F84 PICs static sensitive to ESD?
Old 9th May 2004, 11:55 AM   #2
Banned
in my exerience its difficult to kill a PIC, i even experienced they still are alive after mounting reverse in the socket. In case you buy new, i would use 16F628 or so instead of 16F84
Old 9th May 2004, 12:43 PM   #3
Are they?
Because the kit instruction says that 16F84 is static sensitive...
But I've seen a few people who handled those ICs without a wrist strap...
Which is the truth?
I would like to hear opinions from others as well...
Old 9th May 2004, 12:48 PM   #4
li_gangyi's Avatar
it's probably safer to use a strap...but in all the years of playing with PICs...I haven got any killed yet save for one which I accidentally put too close to my ignition coil and turned the coil on...of course it got fried...but that's outta the point...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 9th May 2004, 12:52 PM   #5
I just wanna tell you guys that I really don't want to damage this chip.
The IC is pre-programed, so I don't even know to program a new IC.
If the IC goes off, the entire kit goes off ( waste of $)
And I don't have any experience with a wrist strap... Do they work on a 'dry' skin as well??
Old 9th May 2004, 01:02 PM   #6
li_gangyi's Avatar
if u're really scared you can just read of the contents save it and if something goes wrong you can easily reprogram another...and yes wrist straps work on dry skin...
Old 9th May 2004, 03:21 PM   #7
Electrons are yellow and more is better!
peranders's Avatar
Default Re: PIC Static Sensitivity
Originally posted by jamesjung21
Hi guys,
Yes!
I suggest that you read the datasheet about that.
In real life they aren't more sensitive than other similar IC but they should be handle with care.
/Per-Anders (my first name) or P-A as my friends call me
Old 9th May 2004, 04:47 PM   #8
Matttcattt's Avatar
Ive never handled them "carefully" and ive never fried one. Even after repeatedly dropping them on the floor, sweeping them up with a broom, putting them in a socket backwards etc.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 10th May 2004, 04:49 AM   #9
Quote: "Even after repeatedly dropping them on the floor, sweeping them up with a broom"
Quote: "and yes wrist straps work on dry skin..."
I wonder how they work even on a dry skin, which is hardly conductive...
Old 10th May 2004, 07:49 AM   #10
li_gangyi's Avatar
consider the 1Mohm resistor already present in the wrist strap...
driver sensitivity vs system sensitivity bvan Full Range 12 5th November 2007 07:57 PM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 11:33 AM
Turn on static? Glowbug Tubes / Valves 3 4th May 2006 04:16 AM
static offroadbum Solid State 1 4th February 2004 12:50 AM
Page generated in 0.09700 seconds (77.53% PHP - 22.47% MySQL) with 10 queries
