| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
1st of all i just wanna say high as i'm new here....hi!
i've been tring to find some caps for my car amp (phoenix gold ms2125) but with no luck the caps i need are 2200uf 16v 105c and measure 18mmx30mm. i've tried lots of websites but no luck, they have smaller dimension caps but as the inside of my amp will be visible under a perspex window i want it to look factory
#2 |
Why not just use 25 or 35V caps? That would make it a lot easier to find caps of the right size.
Best regards, Mikkel C. Simonsen |
#3 |
one company said that it wouldn't harm to go up in volts, is this correct then?
#4 |
As long as you don't go too high in volts in won't cause problems. Using 25 or 35V instead of 16V capacitors is fine - using 200V capacitors is not a good idea.
#5 | |
If it sounds good... it is good! |
#6 |
thanks, that will make it a lot easier to get hold of.
regards mark. |
| Wanted: 10uf mpk caps | audiodan | Swap Meet | 0 | 5th March 2009 11:58 PM |
| Wanted: BHC T-net caps | novec | Swap Meet | 10 | 7th October 2006 06:40 PM |
| all you wanted to know about brands of caps -and were afraid to ask- | federico moreno | Parts | 4 | 30th March 2006 08:48 PM |
| Caps wanted | kgbamps | Parts | 0 | 25th January 2004 04:24 AM |
| Page generated in 0.07175 seconds (79.30% PHP - 20.70% MySQL) with 10 queries |
