Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Fake ELNA capacitors ?
Old 9th May 2004, 08:46 PM   #11
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Fake ELNA capacitors ? Send a message via AIM to Peter Daniel
Default Re: Fake Elna Elcos
Originally posted by kpee
Having worked for Rubycon for 10 years
I bought some BG F series caps recently (1000/35) , and it seems like not standard cap comparing to current BG line. Would you know anything about those?
It is the same size as 1000/50 STD, but has 3 pins.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 9th May 2004, 09:24 PM   #12
grataku is offline grataku  United States
Annex,
that's one instant classic! I m glad you posted it since I had missed it.
I bet whoever used them caps found prodigious improvement in the sound.
Kind of reminds me of some caps I bought awhile ago where, upon shaking, you could feel, and hear, stuff moving inside.
Old 10th May 2004, 03:12 AM   #13
karma is offline karma  Canada
karma's Avatar
more classic than fake
Old 10th May 2004, 08:46 AM   #14
annex666 is offline annex666  England
annex666's Avatar
Originally posted by grataku
Annex,
Sounds like they may be dodgy ones too.
It's worrying enough that the capacitance rating used on the inner cap. on the photo I posted was lower than that printed on the fake casing, but the safe working voltage is also lower - which could potentially lead to any number of dangerous situations, shorts, etc.
Another disturbing story I have heard told amongst the DiyAudio enthusiasts is that of fake transformers!
I believe it was posted that a large, "un-named" company sold power amplifiers using large transformers that appeared to be potted toroids - i.e. large, heavy and plastic coated. One DIYer in his wisdom/curiosity (??) decided that he would cut one of the transormers open only to find a small EI core transformer and a lot of sand!
Shocking!
...if it ain't broke don't fix it - make it BETTER!
Old 10th May 2004, 02:48 PM   #15
kpee is offline kpee  United Kingdom
Default It is the same size as 1000/50 STD, but has 3 pins.
Blackgates are a puzzle as Rubycon will not let them be sold outside japan and should have stopped suppling production quantities 2 or 3 years ago.
Rubycon is only making these under license and the case sizes and specifications are dependent on what is required by the OEM who originally ordered the item. So there are many variations of case size and pin out for the same capacitance and voltage rating
Old 19th March 2005, 03:29 AM   #16
contaxchen is offline contaxchen  Taiwan
Default This is not a fake
HI,
I have bought this from a surplus dealer. The famous Epcos cap.
Its dimensions are all the same as written in the official datasheet, but its weights 120g less. It 's like 250g rather than 420g. I charge it for a minute with 520vds which is 70vdc higher than its design. It is fine with that voltage. It's capacitance is also correct. If it is a fake, must be a very good one. Is there anybody knows a easy way to test ESR?
The best way to stop rust on transformers is to power them up.
Old 19th March 2005, 04:02 AM   #17
budwiser is offline budwiser  United States
Picture of real Elna 10000 63v
Old 8th November 2006, 11:25 PM   #18
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Doh, I wish I had seen this thread before i bought these:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=230042394101
I hope they turn out to be real. I also didn't realise the seller was in china until I had already paid. I'll have to test the capacitance once they arrive I guess.
Also, are rubycons made in the USA? I thought they were made in Japan?
Old 9th November 2006, 04:09 AM   #19
Spasticteapot is offline Spasticteapot  United States
Send a message via AIM to Spasticteapot
Yet another reason why I'm sticking to ordering from Mouser, Digikey, and Apexjr.
At least I know my nichicon's are real. (Not much point in faking those!)
Old 9th November 2006, 01:07 PM   #20
sayang001 is offline sayang001  Netherlands
I have bought GLCD 128x64 from that seller (Sure electronics) and SMD resistors, both items were ok.
Please keep us updated.
Fake ELNA capacitors ?Hide this!Advertise here!
Elna capacitors impsick Everything Else 2 29th June 2011 01:20 PM
ELNA Capacitors - Bargain! VS Swap Meet 6 15th June 2009 11:50 PM
Real or fake Elna Silmic II capacitors Groundloops Parts 9 4th March 2009 05:42 PM
Where can buy ELNA LAO capacitors... zxcxz Swap Meet 0 12th November 2008 09:05 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 10:32 PM
