| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I just added a tutorial to my site showing how to make PCBs yourself. I thought some of you might be interested to see how it is done. There's a lot of pictures and I tried to describe every step as best as I could. However, if you think that something is missing please let me know!
Enjoy: http://members.lycos.nl/anthonyvh/index.php?page=pcb
Website: http://members.lycos.nl/anthonyvh |
#2 |
Great description....well written and easily understandable.
The only thing Id add to it, is that tin plating the boards makes a board a lot easier to solder, and its easily done with some stuff call pcb plater. You can find it from Farnell for reasonable money. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#3 |
"The microweave is used to heat up the etching and developing fluid. You don't need to go buy another microweave, the chemicals only need to be heated for 15 to 25 seconds and they won't boil over such a short time."
Sure this is safe though? Ive always been told to boil water, and then put the dish to be heated into that water. btw nice site |
#4 | ||
Yes, I'm quite sure. I've done it over 30 times now, sometimes I've put the etching solution in it for 50 seconds and nothing boiled over. Of course I can't be sure that your microweave is super powerfull or something About putting dishes into hot water. I tried, it sucks. I have placed dishes in water as hot as 60° and it was barely warm after 5 minutes. Since I'm using a microweave for heating everything goes much better. Try it .)** I updated the page with info on tin plating & temperatures
#5 |
I normally would re-use the etch solution until it loss all the strength.
Can I heat up the used solution in microwave? I do not dare to try it with all the dissolved copper in the solution. Chris |
#6 |
You can reuse and re-microwave, but the copper tends to precipitate and float to the top, and can melt the container if you are not careful. YMMV.
#7 |
I didn't know about that, thanks! I'll add it to the tutorial.
#8 | |
Please finish your JLH first or else! ELSE is well update your tutorial then.. |
#9 | |
aluminium , I guess I'll have to use veneered MDF.The tutorial is updated, I even added a 2nd tutorial, check it out to see what it's about
#10 |
Great work.....this sort of stuff ought to get a permanent link from DIYaudio.
Magura
| Making PCBs - Silicate Developer | Devil_H@ck | Parts | 15 | 22nd April 2012 06:23 AM |
| FS: Aleph-X PCBs , NIGC PCBs , OPA541AM OpAmps | e.lectronick | Swap Meet | 22 | 4th March 2009 07:38 AM |
| Making pcbs, another guide | takeda | Everything Else | 1 | 31st March 2007 09:01 PM |
| Looking for a tutorial? | Carcano | Chip Amps | 6 | 3rd October 2006 05:50 AM |
| Making My Own PCBs | soundNERD | Chip Amps | 81 | 10th June 2005 12:27 PM |
| Page generated in 0.11508 seconds (79.49% PHP - 20.51% MySQL) with 10 queries |
