Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th May 2004, 04:45 PM   #1
diyAudio Moderator Emeritus
jean-paul's Avatar
Default Purple LEDs at last ...
At last a means to go off the beaten track of blue LEDs. I wasn't aware they existed but they do since 2003 :
http://www.ledsupply.com/l3-0-v5th15-1.html
A better link with technical info:
http://ledmuseum.home.att.net/ledvio.htm
No excuses anymore to use that boring blue LEDs on your amps ! For the brave among you there are also amber and turqoise LEDs, I did not check for pink types but I wouldn't be surprised if they also exist.
It's only audio
Old 4th May 2004, 04:50 PM   #2
BrianGT is offline BrianGT  United States
BrianGT's Avatar
Send a message via AIM to BrianGT
Default Re: Purple LEDs at last ...
Originally posted by jean-paul
At last a means to go off the beaten track of blue LEDs. I wasn't aware they existed but they do:
I always thought that the wavelength was too small to create with and LED, but I guess I was wrong. Here is a page with all kinds of purple LEDs:
http://ledmuseum.home.att.net/leduv.htm
Brian
Old 4th May 2004, 04:52 PM   #3
tiroth is offline tiroth  United States
These LEDs can look very cool, but can be painful if you are exposed directly to the light. Probably best used with some kind of diffuser.
The wavelength is generally short enough that you get a blacklight-type effect.
Old 4th May 2004, 05:24 PM   #4
Bricolo is offline Bricolo  France
Bricolo's Avatar
You're right Jean-Paul, blue leds are so rubbish
I use white leds in my stuff, they look so hype
The violet ones also look great, but be carefull. Some manufacturers sell violet leds that in fact are more UV than violet, and can be dangerous for your eyes
Old 4th May 2004, 05:27 PM   #5
Bricolo's Avatar
An easy test to see if a led emits UV
if you haven't any UV reactive toys, simply put the led over a 500€ some UV reactive ink will appear (it also works with smaller ones )
Old 4th May 2004, 11:07 PM   #6
Tensop is offline Tensop  Lebanon
i'd of thought the dangerous UV light(a,b or c?) would of been too little.
it's also going through epoxy/something that would block most of it anyway, not to mention the air also..
Old 5th May 2004, 05:38 AM   #7
Bricolo's Avatar
I don't know if epoxy stops UVs, but for sure air doesn't
Except if you have a big plasma tweeter that produces a lot of ozone in your room, then the ozone will block most of the UVs. But then the ozone will be a bigger concern
Old 5th May 2004, 06:18 AM   #8
Send a message via AIM to groggory Send a message via MSN to groggory Send a message via Yahoo to groggory
purple LED in action
AIM: groggory
Old 5th May 2004, 06:39 AM   #9
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
http://webpages.charter.net/dawill/t...Elec_SSTC.html
But then that's been beefed up to 1/2" spark now, which makes too much noise to be worth much as a tweeter. Plus I wouldn't leave it on, the transistor gets a bit warm just running it for 10 seconds.
Oh, obviously epoxy can't be too bad for UV since there are UV LEDs on the market.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 5th May 2004, 07:21 AM   #10
There seems to be something puzzling here. The wavelengths
stated are really on the borderline of what is visible, and given
the tolerances stated many of the devices wouldn't be visible
at all, if any of them are. It seems one would have to buy a
bunch of LEDs and then select those that happens to be
visible at all.
I question whether a purple LED can be a single-wavelength
device at all. More probably one would have to mix two
wavelenghts, each of them close to either end of the visible
spectrum.
BTW, I have probably told the story before, but when blue LEDs
had just started to appear on the market 20 years ago, a
collegue of mine wanted to use them for a product and phoned
the swedish distributor for prices. The salesman asked what
quantities they were discussing, and my collegues said, well
10k+ quantities. There was a very very long silence at the
other end of the line and then came the response, I am afraid
the yearly production is only about 5000 devices (there was
still only one manufacturer then).
Purple Glow ANDYLASER Tubes / Valves 18 26th April 2009 08:58 PM
Trade my blue LEDs for White LEDs CaliforniaBob Swap Meet 7 26th March 2004 07:28 AM
WTT: Blue LEDs for Red & Red/Green LEDs CaliforniaBob Swap Meet 2 9th June 2003 02:58 PM
7199 glowing purple? GLF Tubes / Valves 10 17th February 2003 11:08 PM
Page generated in 0.10619 seconds (81.06% PHP - 18.94% MySQL) with 11 queries
