Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What type of part is this?  My amp project  :)
Old 3rd May 2004, 01:02 AM   #1
darren01 is offline darren01  United States
Default What type of part is this? My amp project :)
Hello,
I popped open a tube amp of mine to take digital shots to use for my summer project.
There is one type of component that I am not familiar with. It is the metal, square shaped thing pictured below.
This is placed in between the power source and the tube.
Any clue? What does it do?
Thanks in advance.
Darren
Old 3rd May 2004, 01:11 AM   #2
PeteMcK is offline PeteMcK
Default selenium rectifier?
could be an ancient selenium rectifier.
How old is the amp?
Pete McK
Old 3rd May 2004, 01:17 AM   #3
Must be 1959-early 1960s.
It is an amp with an ECL82 tube in it.
What would this specific rectifyer do?
Darren
Old 3rd May 2004, 01:27 AM   #4
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
That is definitely a selenium rectifier. As I recall, they had a forward voltage drop of 1.4v. They have been replaced by silicon diodes.
Old 3rd May 2004, 01:37 AM   #5
Hello,
Thanks for the info.
As part of this project I want to replace all the parts that are not good. Capacitors have to go.
Should I replace this component with a new one or should it be okay?
Darren
(who knows nothing about recitfyers)
Old 3rd May 2004, 01:47 AM   #6
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Most assuridly yes... if it is just a single (half-wave rectifier)you probably want to replace it with a bridge (full-wave rectifier ie 4 x IN4007 would do)
It will have less noise & hum, and you will avoid the not that all uncommon phenomenom of the selinium rectifier depositing its guts all thru-out your amplifier.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd May 2004, 01:56 AM   #7
Default the 1n4007 and another part
Thanks for your answer.
You said "full-wave rectifier ie 4 x IN4007 would do."
Do I put 4 of these in series in place of the original?
I see Digikey.com has many types of 1n4007. Which is the best to get?
Here is another part I have questions about.
It appears to be a four-in-one type of capacitor. Picture is down below.
Two out of the 5 leads go directly to the tube, one goes to ground, one to the rectifyer, and one to a resistor > tube.
It is a 60-60/40/25 mf capacitor with voltage values are 250-250/200/25.
Do I replace this capacitors with 4 equivalent Electrolytics?
Darren
Old 3rd May 2004, 03:08 AM   #8
frugal-phile(tm)
planet10's Avatar
Default Re: the 1n4007 and another part
Here is an article i did on a simplier, but similar amp with scematic & pictures, look at the power supply
http://www.t-linespeakers.org/tubes/SEP_50EH5.html
Yes, althou there are some places where you can get multipart elcos for restoration purposes.
Before you do anything you want to trace out the circuit (this is a very valuable learning experience)
this site will be helpful
http://tdsl.duncanamps.com/tubesearch.php
dave
Old 3rd May 2004, 03:11 AM   #9
frugal-phile(tm)
planet10's Avatar
this scematic of Morse's 6BM8 amp (there is a whole thread on it) will be roughly the same as yours (at least in terms of where things should be -- values may be different -- your amp may well have a bypass cap in the cathode of the pentode)
dave
Old 3rd May 2004, 05:20 AM   #10
Default Re: Re: the 1n4007 and another part
Hello,
Thanks, again for the replys. You are very helpful.
This isn't a restoration job. I am aiming to bring this stylish 40+ year old tube amp'ed Stereo Reel to Reel Hi-Fi system up to date.
It isn't worth more then $10 as it is. Other RtR recorders from the same era and by the same manufacturer rarely sell on eBay even when listed at $5.
Very heavy. Postage is more than the value of these things, I recon.
I tried it just now and am no good at it. I am much better at point-to-point removal and replacement soldering.
Show me a scematic and I am lost. Show me the physical finished product and I understand it.
dave
Thanks for the tips and hints.
As stated above, I just want to bring this up to date as much as I can for the fun of it.
I got some old reel to reels. Hours worth. It would be great to be able to listen to them in better quality or even record over them in stereo.
Taking all the old capacitors out and replacing them with good audio grade or better one, replacing the recitfier and putting new plugs and jacks on it is the mission.
Basically, I am hoping for something that sounded better when bought new.
I will be posting at DIYaudio.com very often as I find the parts and progress is made.
There will also be a website. I have over 40 photos taken for it already.
Back to the rectifier thing. Do I solder all four of these in series?
Can someone show me an example of how this is done? I am ordering those parts, along with others, tomorrow afternoon.
Darren
What type of part is this?  My amp project  :)Hide this!Advertise here!
FS: Project Boards (solder type) nukaidee Swap Meet 6 24th March 2009 03:27 AM
I need car MP3 Player Project ( using old PC part ) pasan Car Audio 2 19th March 2007 03:31 AM
My Fostex FE 108EZ project, Part 2 Taperwood Full Range 21 13th April 2006 02:48 AM
My balanced power project part I with pics DIY_newbie Multi-Way 1 9th May 2005 02:48 AM
Need help finding simple part for project d-audi Tubes / Valves 7 29th October 2002 11:47 PM
Copyright ©1999-2017 diyAudio
