Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
12 channel volume control
Old 30th April 2004, 09:47 PM   #1
CRFX is offline CRFX  United States
CRFX's Avatar
Send a message via AIM to CRFX
Default 12 channel volume control
I'v been looking around for a way to control the volume on my 12 channel amp, but haven't found a decent solution. The best I could find was a 6 channel pot, or go with digital control. (probably the best way)
I wondering thogh are there pots that can just be connected together modualy? That way I can string together as many as I need. Haven't been able to find anything like that.
Thanks,
Chris
Old 1st May 2004, 04:37 AM   #2
djmiddelkoop is offline djmiddelkoop  Netherlands
djmiddelkoop's Avatar
Try Allen Bradly Mod Pot.
They can be stacked as much as you like.
Dick.
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 1st May 2004, 07:02 AM   #3
CRFX's Avatar
Is this one of them?
http://www.allelectronics.com/cgi-bi...-5K&type=store
If so I'll be getting a few of them, looks like its just what I need.
Thanks a bunch.
Old 1st May 2004, 05:22 PM   #4
Just make shure you buy the correct version.
The ones I mean have a special connection part iso a shaft, so when you remove the back of the front unit, you can connect the second and so on.
Dick.
Old 1st May 2004, 07:45 PM   #5
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Hey CRFX,
Those 5k pots would be great for my SOZen.
Especially since it would take 4 decks to control a stereo pair since the amps are balanced.
PLEASE report if the pots can be stacked into huge assemblies!!!
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 1st May 2004, 08:06 PM   #6
A3rd.Zero is offline A3rd.Zero  United States
A3rd.Zero's Avatar
After taking apart a alps blue velvet it seems easy to stack these as well. You only need remove the label at the back and epoxy the shaft of the second to the rear end of the shaft of the first.
Its not plug and play, but it is DIY.
Milo
How did I live without Nina Simone for so long?
Old 1st May 2004, 09:04 PM   #7
diyAudio Editor
Variac's Avatar
For those of us who don't trust epoxy in a torsional situation,
I suppose one couuld cut a slot in each shaft and connect with a short strip of metal (and maybe hold in place with.....epoxy?)
Still a pot made to stack sounds perfect. I mean it would be a perfect choice , but we don't know how it sounds
Old 1st May 2004, 10:10 PM   #8
owel is offline owel  United States
Default VCA
If you go to THATCORP.COM, check out their VCA's. They have an appplication note that will let you control many VCA's using only (1) potentiometer, via a DC control voltage.
You can use their VCA's as preamps for your amp, and volume control.
Old 1st May 2004, 10:51 PM   #9
A3rd.Zero's Avatar
Unfortunately the shaft that moves through the pot is much smaller 1/16" diameter, so slotting it might not work. If you used jbweld however and countersunk a hole in the receiving shaft then glue the two together I think it would be safe and stable.
Ill try to take a picture of the inside or scan one and post it tonight.
Milo
edit: wow i really can't spell
Old 2nd May 2004, 05:29 AM   #10
CRFX's Avatar
I going to take a look at the ones I mentioned b4, only a buck each.
While looking at some sliding pots I figured if I just attached a bar to the slider I could move them all at once. Plus by offseting them I could pre set the balance between them.
12 channel volume controlHide this!Advertise here!
6 Channel Volume Control dannybeckett Solid State 16 22nd July 2014 03:51 PM
WTB: 6 Channel Volume Control patherb Multi-Way 6 24th March 2009 04:20 PM
FS: 6-channel volume control (DCX2496) tf1216 Swap Meet 10 2nd October 2008 11:01 PM
4 channel volume control Wynand Chip Amps 4 6th August 2005 04:52 AM
Six channel volume control? Bas Horneman Everything Else 8 25th April 2002 05:03 AM
