Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th April 2004, 06:00 PM   #1
A3rd.Zero's Avatar
Default Capacitors as powersources
I am interested in using a capacitor as a powersource, much like a battery. I am however, a noob in terms of my understanding of electronics. If I have therefore a 50F capacitor that runs at 3.6V and I have a current draw of 3V an 30mA, what is the equation for figuring out how long this capacitor will supply power?
I know that Capacitors discharge over a curve, is it possible to use a voltage regulator to keep the discharge reasonably flat? If used will a voltage regulator consume much power just by existing in a circuit?
Thank you for your help. I am sure that many of my questions sound silly to many of you.
Milo
How did I live without Nina Simone for so long?
Old 27th April 2004, 10:23 PM   #2
Bill Fitzpatrick's Avatar
http://www.tpub.com/neets/book2/3d.htm
Old 27th April 2004, 11:46 PM   #3
A3rd.Zero's Avatar
Thank You!!!!!!!
Old 28th April 2004, 12:01 AM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Hm, 50F at 30mA eh? What is your cutoff voltage?
For a resistive load the equation is: V = Vo * e^(-t/RC), where Vo ("vee naught") is the initial voltage (3.6V), V is the voltage at time t, R and C are the obvious circuit constants and e is the natural base (2.7 something). Some algebra can solve for t rather than V. For small changes in voltage the resistor looks like a constant current sink and the equation reduces to dV/dt = CdQ/dt. But I didn't get enough sleep to figure the rest so...l8r...
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 28th April 2004, 01:58 AM   #5
A3rd.Zero's Avatar
This is all good info but it has generated another question. I have figured out the requirements for one led with resistor run off a 50F capacitor and it looks at least experimental, but if I add led's in parallel then I will be drawing more current. How do I figure current draw into this equation? Thanks for your help.
milo
Old 28th April 2004, 02:18 AM   #6
Sch3mat1c's Avatar
For LEDs, the dynamic resistance the cap sees (as a power supply vs. load situation) will be equivalent to the total series current-limiting resistor values. So say you have four red LEDs with 100 ohm current limiting resistors: 100/4 = 25 ohms would be used for R in the formula.
I hope you aren't using blue or white LEDs on a 3.6V rated capacitor, as to have adequate voltage overhead to limit current (with the resistors) you'll need more like 5V. 6 to 8V would be even better as far as intensity stability is concerned... it'll drop off quite quickly as you can only use the voltage between when the LEDs turn on, and the max. voltage you are using. (Blue LEDs might turn on at 3V; using 4V on the cap gives 1V of mildly usable range, all of 25J. Life might be 6 minutes? Just guessing...
Tim
Old 28th April 2004, 03:11 AM   #7
DUG is offline DUG  Canada
Or you can use a constant current draw as a model.
Basic formulae:
C=Q/V
i=Q/t
(I'm leaving out the delta's on purpose)
The first one can be re-written as Q=C*V
The second one can be re-written as Q=i*t
Q=Q
then C*V=i*t
or re-written as t=C*V/i
in words: the time it takes a 35F cap to drop 1 V at a current of 1 A is 35 seconds.
for 0.1 Amp 350 seconds
for 0.01 amp 3500 seconds
etc
Also to charge that capacitor to 3.5V with 1 Amp would take over 100 seconds
I use this (and some trig) to calculate ripple on power supply filter capacitors.
Doug We are all learning...we can all help
Old 28th April 2004, 06:31 AM   #8
Sch3mat1c's Avatar
Ah, that's what I needed... thanks
Tim (still tired, and going to bed soon)
capacitors reddish75 Solid State 4 19th May 2008 10:16 AM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.09828 seconds (81.22% PHP - 18.78% MySQL) with 10 queries
