Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th April 2004, 08:59 AM   #1
Kari is offline Kari  Sweden
Kari's Avatar
Default High grade replacement transistors.
can anyone suggest "better"/audio grade transistors for BC550C, BC559C and BD139?
Thx,
Kari
Old 27th April 2004, 10:07 AM   #2
baggystevo82's Avatar
Send a message via MSN to baggystevo82
BC550C is already the low noise version of BC550 isn't it?
Steve
Old 27th April 2004, 04:02 PM   #3
Did it Himself
richie00boy's Avatar
No it's the higher gain band version.
The devices you quote are already good audio devices and staying within the contraints of the packaging I doubt any better can be done.
The only comment I would make is that BC550/560 are a complementary pair, as are the BC549/559. So if you are using the devices listed as complementary pairs you are not using the optimum solution.
Old 27th April 2004, 04:14 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
Kari, you have lot's of types to choose from but all depends of what you are going to use those for and how easy there are to get.
BC5xx (BC8xx SMD) and BD139/140 are good in it's class.
If you state your needs I'm sure we can come up with something.
/Per-Anders (my first name) or P-A as my friends call me
Old 27th April 2004, 05:08 PM   #5
Kari's Avatar
i'm in the process of building a discretecomponent setup of ZapFilter2. I'll go for BC560C instead of BC559C. I was just wondering if there where any "audio" marked transistors.
Thx,
Kari
Old 27th April 2004, 09:09 PM   #6
Did it Himself
These transistors *are* 'audio marked' devices!
You may be able to improve a little on the BD139 with one of the new ONsemi devices, MJE15034. If this is hard to get (very new release) then try its predecessor MJE15032. But beware that these are a TO-220 case and the pinout is reversed.
For small-signal my 'special drawer' has Sanyo 2SA1016 and 2SC2362 in it. But these devices have a totally different pinout to the BC5xx series and are fairly hard to get.
I really don't think you will notice any difference using other than BC550/560 - they are high gain linear devices. Better spend your time and money on something that will make more difference, like bigger/more power supply caps/better regulators.
Rebuilding a DAC Audio grade or Computer grade caps? gto127 Digital Source 0 28th January 2009 08:17 PM
WTB: 2pcs HIGH GRADE 0.22uF PIO (JENSEN or other) cartman Swap Meet 0 25th May 2006 06:31 AM
Best competition high-grade, affordable sub system? Recycle-Bin Car Audio 11 25th May 2004 01:05 AM
PEH169 RIFA High performance computer grade caps peranders Swap Meet 4 26th November 2002 12:54 PM
High Grade Midranges Myren Multi-Way 9 17th December 2001 04:42 AM
Page generated in 0.08388 seconds (76.01% PHP - 23.99% MySQL) with 10 queries
