Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th April 2004, 04:18 AM   #1
Send a message via AIM to AJ Bertelson
Default Any differences between wire types?
Just noticed this when I got home today after picking up some 20 gauge wire.
Red-Copper multi stranded
White-Appears to be alluminum(silver color) but it is multistranded
Black-Single strand wire that is copper
I will be using this wire up one of my amps but I am not certain if I want to go back to the store to pick up some more wire.
Any differences in the wire at all?
Old 26th April 2004, 11:55 AM   #2
Did it Himself
richie00boy's Avatar
Red - seems fine.
White - probably just tinned copper wire. If it's aluminium you won't be able to solder it
Black - I prefer stranded wire as it's less likely to break due to bending fatigue. I'd also use the same type of wire for both power connections (assuming red is +ve and black is -ve).
Old 26th April 2004, 10:04 PM   #3
Magura is offline Magura  Denmark
Magura's Avatar
The wire type used to wire up an amp has no influence on the sound as is. There are however a few factors worth taking into account.
As richie00boy pointed out there is a benefit of using multistranded wire to avoid fatigue during the building process.
Also worth taking into account is that you would want either fibreglass or teflon insulation for the sake of saving your a$$ if something goes wrong and gets hot. To use a wire type that offers a little more protection in case something fails or during error correction.
At last but also important is to choose a type of wire that is plated. Raw copper will oxidate, and under the right (wrong?) circumstances, even rather fast. So the wire should at least be tinned. I have though seen tinned wire corrode as well, especially on the negative side close to the power supply. The solution for this is silver plating.
Team up with a couple of other americans and buy a roll of Habia E-1819. Habia in USA is maybe a little easier to deal with....minimum order will though be at least 500 meters, but then you will also get it for a reasonable price. You should be able to get it for around 1.33 USD per meter.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Wire Types AmpBuilder225 Tubes / Valves 0 25th February 2009 09:35 PM
Differences with 6C33 Tube Types korneluk Tubes / Valves 4 27th March 2008 05:00 PM
Practical Hookup Wire Types/Sizes CarlosT Chip Amps 4 7th December 2006 11:47 AM
Wire types?? gingertube Tubes / Valves 5 18th March 2005 02:24 AM
Speaker Wire Types? FrankRoss Multi-Way 2 28th January 2003 12:56 AM
Page generated in 0.07304 seconds (76.59% PHP - 23.41% MySQL) with 10 queries
