| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
hey guys, i found a circuit that im trying to work with, but there is a big plastic block in it. i unscrewed it to find that its been potted, filled to the brim with epoxy. there are 3 wires going in, and 3 coming out, and im very curious whats in there... whats the best way to get rid of the epoxy without ruining whatever is in there. (i am assuming its not a sensitive IC, its a pretty small block, 2"x1"x1".) one side appears to have a small inductor or transformer in it.
i did some searching and found that acetone or heat would probably work. is there a way of telling what kinda of epoxy (or if it is epoxy?), and what would work best? thanks guys. |
#2 |
What kind of circuit is it? Often you can figure out what is in it by looking at the rest of the circuit. Or you can try to measure differences in output with various inputs. This can get awfully complicated, though!
Dave Kimble |
#3 |
its a very simple circuit... it has another "thing" that i suspect is a dc to dc converter... but i am not sure yet.
i am a little hesitant to reveal the circuit because im working on it for a patent, and im taking apart a few other circuits to find out what i can and cant use, etc... i just need to remove the potting if possible. |
#4 |
#5 |
cool, thanks!
i think freezing and chipping away will probably be the best solution... maybe melting the epoxy next. either way, it will be work. |
#6 |
Ever thing of going to your Dentist and having them x-ray it ???
#7 |
Depending what type of epoxy it is, you can heat it up by boiling it and it becomes soft enough to be removeable.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#8 | |
haha, that could be expensive! but i dont think it would tell me values right? i would want to know values.
#9 |
No values, but he could tell you if it needs a root canal or something. Has it been flossing.
Sorry, I amused myself though. |
#10 |
hum.
well, i kinda half tried the compressed air thing. yes, upside-down it does freeze, but even after icing the whole thing, and giving a good whack with a hammer, it does nothing. i think melting it would be best. or using a solvent of some sort to melt it away. |
| Removing old glued chunky components | wiredmonkey | Solid State | 8 | 22nd July 2009 01:36 AM |
| AR SP-4 Preamp- potted modules | Conrad Hoffman | Solid State | 0 | 1st February 2008 12:48 AM |
| Potted transformers | semitone | Tubes / Valves | 22 | 13th January 2008 12:00 AM |
| potted transformers | resident | Tubes / Valves | 24 | 13th November 2004 05:55 PM |
| SA-25 NEXUS potted op amp- What is ext pot for? | ljordan | Everything Else | 1 | 22nd February 2004 10:42 AM |
| Page generated in 0.10032 seconds (77.21% PHP - 22.79% MySQL) with 10 queries |
