Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th April 2004, 12:32 AM   #1
roibm is offline roibm  Romania
Banned
Question Print transformers: what are they good for?
Saw some good auction on ebay, 10 pieces print transformers like pictured bellow:
They are rated 115-230V and 2x9 3.5A
Any ideas what could be achieved with these?
Any good for audio? Good for use in a PSU for opamps or a DAC?
thanks
Old 24th April 2004, 04:01 AM   #2
Bill Fitzpatrick's Avatar
What do you mean by "print transformer?"
Old 24th April 2004, 07:19 AM   #3
roadkill's Avatar
I guess he means "PCB mounting" transformer.
Yes, this would be quite useful to power a preamp, DAC or crossover board.
See this thread for a picture of a DSP board which uses similar transformers.
Old 24th April 2004, 07:38 AM   #4
Electrons are yellow and more is better!
peranders's Avatar
They are very pratical in general!
See here
/Per-Anders (my first name) or P-A as my friends call me
Old 24th April 2004, 07:50 AM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
They should be used with caution on DIY kit, as their use puts mains on the PCB.
I always have mains voltages double insulated and separate from the low voltage electronics.
Old 24th April 2004, 07:56 AM   #6
analog_sa's Avatar
John
You always try to take the fun away from DIY A different approach
Old 24th April 2004, 08:05 AM   #7
dhaen's Avatar
That's very funny, in coincidental way.
Compare:
His estate or personal representative brought a §402 A product liability action,
...snip...
with:
Q: What on earth is a 402 error?
A: This error code is puzzling. According to the HTTP specification, this code is reserved for future use and means "Payment required"
...snip..
Ok, so I'm a crank...
Old 24th April 2004, 08:13 AM   #8
ARAD is offline ARAD  Germany
roibm,
the transformer in the picture is a very small transformer - it is rated at 2x9V and delivers 2x 3.5 VA (not A)... what translates to a little less then 400 milliAmps per secondary.
Andreas
Old 24th April 2004, 09:16 AM   #9
Circlotron's Avatar
Default Hummmmmmm..
Not only for safety - you want to keep mains wiring as far away as possible from low level signal wiring.
Old 24th April 2004, 09:49 AM   #10
Thomas is offline Thomas  Denmark
Thomas's Avatar
I use a small print transformer to drive the relays and LED's in a amplifier I'm building. Good thing about this, it keeps the "foreign" circuitry out of the signal path and got the correct voltage for the relays I'm using.
Anyone compared electra-print SE:PP interstages to electra-print PSA-2 autoformers zobsky Tubes / Valves 0 11th June 2009 05:39 PM
Scr gate transformers, any good? Andypairo Digital Source 1 6th July 2008 03:45 PM
Are Hammond power transformers good enough ? lowtherdream Tubes / Valves 23 13th May 2007 01:33 AM
Good prices on transformers, where? Bricolo Parts 6 22nd June 2004 09:20 AM
good place for transformers zx3chris Parts 8 10th February 2003 04:18 PM
Page generated in 0.09394 seconds (79.50% PHP - 20.50% MySQL) with 10 queries
