| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
How do I diy Hi-End filter power supply and power cord?
#2 |
Banned
with some inductors and some caps?
#3 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
I'll reply if he won't
One Class-A monoblock, toroidal transformer, 12 Watts output power. 1) How big the toroid should be ? As I've heard, it shall be quite oversized for very good results. 200VA for example for that 12 Watt tube power? Or more ? Less ? 2) rectifying with diodes, Graetz-bridge, no tubes. Buffer capacitor will be one huge electrolytics with about 100,000 uF (0,1 F) for lowest 50-Hz ripple. A small ceramic or metal-film capacitor with small capacity (for example 470uF) will be parallel-connected with it, just to avoid the lush slow sound of the big one and improve highs. What about that all ? Can I find diodes on the market which are capable of feeding such a big electrolitycs constantly? (They will be protected for over-Ampers when turning on the device, of course). Any other ideas for that all rectifying and filtering? 3) Is there any need of stabilizing the supply for the tube circuit (all DC of course)? 4) Heating will be 6,3V DC, separate transformer, whole separate circuit, even turning-on the amp will happen in two steps: 1st switch on, heating enabled. Wait for 1-2 minutes. Then 2nd switch on, amp enabled and usable. Now the question follows here, too: how big (or small) transformer should I choose for the heating's 6,3V DC ? There are 4 tubes per monoblock, all of them requiring 6,3V DC heating at different mA values. 2x365mA + 800mA + 1,6A. I go further: does heating need to be stabilized? Is it completely unnecessary, or does it have a sense, even if not too much ? Will I hear the difference? Thank you |
#5 | |
Of course, if you need earth, you need another wire...
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#7 | |
If correct, and bmpa is interested in filtering the mains, my suggestion is to buy a surplus isolation transformer, or two of them _grin_ My reasoning is that quite possibly you could buy the complete setup cheaper as business or industrial salvage than you could buy the parts. Not much DIY involved, but cheaper and easier. I have two 1450 watt Powervar's. I just plug one Powervar into the other Powervar, and plug all of the audio stuff into the powervar that's at the end of the chain. Works well, and is cheap. Regards Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
| Separate power supply - Umbilical Cord | marcutan | Tubes / Valves | 39 | 27th January 2010 07:18 PM |
| Grounded power supply cord on a transformerless amp ? | bereanbill | Tubes / Valves | 5 | 7th June 2009 11:11 PM |
| Power supply filter mod | Ty_Bower | Tubes / Valves | 3 | 21st July 2007 01:50 AM |
| Why not put filter caps in power supply? | Joshua Layne | Chip Amps | 7 | 31st January 2004 03:50 PM |
| How do you make a power supply umbilical cord?? | raincheck | Pass Labs | 8 | 16th January 2003 01:14 AM |
| Page generated in 0.09837 seconds (75.53% PHP - 24.47% MySQL) with 10 queries |
