| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Subject kinda says it. I know ESP and Welborne Labs have them, anyone else?
#2 |
Theyre quite easy to make, even kitchen table technology will do.
If interested I can find the dimentions you need for you. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#3 |
These are actually easier to do than to buy. You need a simple trip to your local hardware store (or something similar to Home Depot). First find their metal department. Get some 1/4 inch aluminum rod http://www.onlinemetals.com/merchant...owunits=inches , have them cut to the length you need. Next look for set screw coupling (this should look like the part 2424k11 at www.mcmaster.com ). For approximately $6 a foot you just "made" your own shaft extender.
(You can even order everything you need online Hope this helps! Sébastien |
#4 |
Exactly my point.
I though usually couple the extender with the pot with a sleeve and a little epoxy. Magura EDIT: Damn, this was my post number 1000.....it seems like I joined this forum just recently, obviously thats not quite the case
#5 |
Epoxy makes it more work when you need to replace the potentiometer though but it is sure cheaper than the coupler!
Sébastien |
#6 |
Above all, the epoxy solution is easy, its something anybody can do.
If you buy a pot of reasonable quality, it should not be nessecery to replace it for a long time. Ive got volume pots that are more than 10 years old and are used every day. Good pots are not expensive, and the money is well spent. Magura
#7 |
Epoxy is not recommended, as if the shaft and pot is not perfectly aligned, the action won't be smooth. A flexible pipe is much better (water supply pipe, 1/4 internal dia). It's easy to cut and fits snugly over the pot's shaft and 1/4" rod (used as extender).
| Where to get pot shaft extension? | Dustin Haug | Parts | 27 | 16th August 2011 01:47 AM |
| Can I adapt the shaft of a pot? | vvangelovski | Parts | 7 | 23rd May 2009 05:15 PM |
| shaft extender | JAZZ2250 | Parts | 4 | 7th July 2003 04:01 PM |
| Source for Shaft Extenders | Panelhead | Parts | 9 | 14th February 2003 10:36 AM |
| Page generated in 0.09822 seconds (79.55% PHP - 20.45% MySQL) with 10 queries |
