Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd April 2004, 02:19 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default When you build something, do it always work at the first powerup?
I just want to know if there are lucky people here
Old 22nd April 2004, 02:24 PM   #2
Fuling is offline Fuling  Sweden
Mostly, but defintitely not always!
Old 22nd April 2004, 02:31 PM   #3
chris ma's Avatar
My very first time powering up my very first diy project JLH 1996 I did not know what to do with my multimeter so I phoned someone that knows electronics and asked him for help. During our conversation I noticed something on the amp that I made a remark to my helper over the phone
I said " How come there is only one light blub comes on but the others do not ?"
He asked "What light bulb?"
I said " Isn't that there are build in light bulbs in those white rectangular ceramic 10W resistors?"
He shouted " Turn it off, OFF"
No in my case, not always work, I'll say may be 10% works first time.
Chris
Old 22nd April 2004, 02:35 PM   #4
Bricolo's Avatar
Chris
Old 22nd April 2004, 02:41 PM   #5
Bricolo's Avatar
It seems that I'm on a lucky day.
I spent 3 hours soldering my kwak clock, and it seems to work.
But it's not always like this. Most of the time it's onle a small mistake. Like the day I finished my headphone amp but couldn't get any sound out of it. Quite normal when the output jack is connected to the input, and the input RACs to the input
I think my gainclone worked at the first powerup. But later I wanted to add some PS filtering, and I wired the caps the wrong way (the cap's - to ground, on both rails)
When I switched it on, the speaker made bzzzzzzZZZZZZZZZZ PAF!
And a pair of capacitors thought they were bullets and flyed at the opposite corner of the room.
Old 22nd April 2004, 03:00 PM   #6
Send a message via AIM to AJ Bertelson
I was a bit worried that something like this might happen to me so I loosely wired up the top part of my case and I forgot to ground the switch to the chassis correctly. Well once I fired it up it sounded great so I jumped up with joy and when I landed on the floor I think it disturbed the ground because after that it started making a hum then started to crackle(from the speakers). Quickly turned it off and checked the fuses. Blown to smitheriens.
got it working after going through another set of fuses. Third time was a charm.
Old 22nd April 2004, 03:09 PM   #7
MikeB is offline MikeB  Germany
MikeB's Avatar
Oh yeah i know this " the speaker made bzzzzzzZZZZZZZZZZ PAF!"
All started fine, playing some music, and then suddenly.. BANG !
You can't imagine how loud a detonating transistor can be !
After hearing again, i heard the speakers bzzzz.
The plastic case from the transistor has gone completely, leaving
three naked legs...
Maybe a 0.5kw PSU with 2x22000uF is quite powerful ?
The Fuses weren't impressed at all, seems that slow means SLOW !
Mike
Old 22nd April 2004, 03:16 PM   #8
PCC88 is offline PCC88  United Kingdom
Default Re: When you build something, do it always work at the first powerup?
Absolutely, works first time every time.......
Old 22nd April 2004, 03:35 PM   #9
ashok's Avatar
Default Can be spectacular at times.
After many years of having success and failure on first time switch on , I made an amp for use in my friend's car. Things like faulty capacitor polarity etc were things of the past.
We connected up everything and turned it on. There was no sound at all. Then suddenly there was a bang and the car was filled with smoke. Can't tell you how embarassed I was.
Apparently the car was wired with positive ground ( long ago !).
I just assumed that it was like normal cars with negative ground. Lucky the capacitor was inside the amp. The amp was ruined of course. Too much electrolyte all over to clean up.
Errors still take place and probably will keep happening. Sometimes with spectacular results.
Ashok.
AM
Old 22nd April 2004, 03:41 PM   #10
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Sometimes they do, sometimes not.
The interesting thing is that those that do not, get developed much further. It comes from gaining more knowledge by having worked on them.
The more difficult it is to get working, the better ...... I must be a masochist
QED A240CD Blows Fuse on Powerup Funky971 Solid State 38 21st May 2012 04:34 AM
MC2105 blows fuses on powerup philosophy Solid State 18 10th October 2009 03:22 AM
Snap sound on preamp powerup trombone Tubes / Valves 2 1st February 2006 06:56 PM
Dimmer For powerup? CryingDragon Solid State 17 19th September 2002 04:50 PM
Page generated in 0.10414 seconds (79.70% PHP - 20.30% MySQL) with 11 queries
