Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st April 2004, 09:57 PM   #1
mkruger is offline mkruger  United States
Send a message via AIM to mkruger
Question RFI/EMI Shielding, is it necessary?
Iv'e always assumed when building my tube mic pre that using an RFI shielded case was necessary becuase the components/wires inside are not shielded. I've been using Par-Metal 14U series shielded cases for this. I noticed they also make a table top case specifically for amplifier and hi-fi audio projects that's not shielded. Both cases I've mentioned are made from the same aluminum-alloy.
So this made me think... Is the shielding necessary? Or should I be asking does metal, such as aluminum, provide enough shielding on it's own? Thanks for your help!
-mike
Old 22nd April 2004, 05:54 AM   #2
runebivrin's Avatar
Send a message via MSN to runebivrin
A metal box forms a Faraday's cage, which blocks any RFI quite well.
Near as I can tell from Par-Metal's web site, the 14U case is designed to have no openings what so ever, with overlapping edges, to completely block any form of RFI.
I think you'll find the table top case work well enough for these purposes. Particularly since you're building a tube thingy, which could probably use the ventilation. You can always cover the vents with a fine metal mesh if RFI should prove to be an issue.
Rune
Do wizards use spell checkers?
Shielding ..... sakis Solid State 9 20th July 2009 07:34 AM
EMI shielding... how? taj Parts 10 16th March 2006 02:23 AM
Shielding Lostcause Everything Else 12 8th November 2005 02:30 PM
Shielding KornChild5 Everything Else 0 3rd May 2005 06:37 AM
Shielding peterr Everything Else 2 17th September 2002 11:57 AM
Page generated in 0.06019 seconds (71.22% PHP - 28.78% MySQL) with 10 queries
