| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi. Does any of you have a list of permeabilties of different metals. I would like to know permeability of copper, u-metal, stainless steel, aluminium and steel. What other things matter to magnetic shielding than permeability?
#2 | |
Iron 150 Permalloy 8,000 Nickel 110 Steel 50 Mu metal 20,000 Copper 1 Aluminum 1 Stainless 1 (depends on composition) Personally, I would be looking at how the material is to work with, i.e., cutting, drilling, welding, bending, etc. Regards, Rob |
#3 |
Hi. What happens to stainless steel`s permeability when it is heattreated or welded? Thank you for your list.
#4 | |
se |
#5 |
I like to refer to figure 16 here: http://www.analog.com/UploadedFiles/...6254AN-347.pdf
BTW I like steel's shielding ability (easier to get and work with than mu-metal). JF |
#6 | |
Anvil...skin depth of the material plays a role also. depth (cm) = 5033 * sqr(p/uf) p is resistivity in ohms per centimeter cubed u is permeability for low flux densities f is frequency When SS is welded, it can allow precipitation of carbon, rendering it magnetic. Also, it can become slightly magnetic when machined. Cheers, John |
#7 | |
| unknown permeability... wind or no? | Stocker | Parts | 13 | 8th January 2005 03:55 PM |
| Permeability of transformator cores. | Gunders | Parts | 5 | 19th February 2003 12:52 AM |
| Page generated in 0.07972 seconds (77.66% PHP - 22.34% MySQL) with 11 queries |
