Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
5532 opamp replacement
Old 23rd April 2002, 07:36 PM   #1
2Bak is offline 2Bak  Denmark
Default 5532 opamp replacement
I was planning to replace the two OP amps in my old Sony CDP-x222ES: These are RC5532DD (L Ray 10688), see
http://2bak.homepage.dk/opamp.jpg
I'm also doing a Clock modification with LClock from LC Audio + various mechanical tweaks.
My question is: Which good audio IC's could replace the 5532's dual op amps in my Sony? I will plug in two 8 pin dip sockets so I can easily swap and test different types.
Would OP275 be OK? Or AD712? Or... ?
Thanks /Jan
Old 23rd April 2002, 08:01 PM   #2
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Hello Jan,
you could try the AD825 module from LCAudio wich uses two single smd opamps that can be plugged into a dip8.
There´s also the possibility to use one or two OPA627 AU with the same module.
If you want to use a dual opamp try an OPA2604 (rel. cheap) or OPA2107 (rel. expensive)
I tried them all and think that the AD825 module is the best value.
william
Old 23rd April 2002, 10:18 PM   #3
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Hello Jan
If the AD825 modules from LC seems too expensive for a first try, then you can experiment with the OPA2132 or OPA2134 instead. I don´t know where you get your components (der er jo ikke så mange elektronikbutikker i Helsingør :-) but RS and Farnell carries both versions and they´re both in DIP-8 packages, so they are easier to work with than the 825.
Hope this helps!
/Uffe
Old 23rd April 2002, 10:39 PM   #4
sonnya is offline sonnya  Denmark
sonnya's Avatar
Send en mail, hvis det er svært at skaffe varen.. Jeg tror jeg har OP275GP liggende. hehe did you all get this!?
Sonny
Old 24th April 2002, 10:08 AM   #5
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default The easy way
I would recommend you to replace the NE5532 with of good upgrade and I think OPA2134 and OPA2604 are excellent choices, and easy also!
Buy them from http://www.elfa.se
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 18 pcb's in interest.
Old 29th April 2002, 05:44 AM   #6
mnewport is offline mnewport
Default 5532 replacement
Try the AD826. It's a dual opamp, it has better specs than the AD825, and it's less expensive than
the module from LC audio. It's also pretty stable. I haven't had to bypass or decouple one
yet. The Burr Brown stuff is nice, but the 826
definitely beats them in terms of clarity and transient response.
Matt
Old 30th April 2002, 09:04 PM   #7
Thanks all.
I installed the LC Audio AD825 (old model), and I'm pretty satisfied. More details, well defined treble, firm bass.
Didn't apply any decoupling capacitors yet...
http://2bak.homepage.dk/analog.jpg
http://2bak.homepage.dk/ad825.jpg
Old 5th May 2002, 04:43 AM   #8
morsel is offline morsel
morsel's Avatar
Check out this thread:
http://www.diyaudio.com/forums/showt...?threadid=3212
The HeadWize and Head-Fi gurus say the AD826 is not as good as the AD8610 or AD825. The AD826 is bipolar input, not FET, which is a big black mark in my book. I am still waiting for my AD826 to arrive. Analog was backordered about a month on them. I have not actually heard it yet, but I don't expect it to be a chip of choice. The AD8610 and AD825 are both great.
5532 opamp replacementHide this!Advertise here!
ne 5532 replacement intense-tavda Digital Source 3 30th August 2013 01:52 AM
Best opa604a opamp replacement? KLe Solid State 26 23rd December 2008 12:11 AM
OPAmp replacement jpy1974 Chip Amps 5 12th March 2007 02:14 PM
LM709C opamp replacement pjpoes Parts 0 9th January 2007 03:34 PM
Opamp Replacement Help tone Digital Source 1 19th August 2002 05:41 PM
