Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Chassis service?
Chassis service?
Old 10th July 2018, 04:06 PM   #11
mbates14 is offline mbates14
Originally Posted by FullRangeMan View Post
[B]The Chinese wont deal with me unless I am making 50 or more pieces. <snip>
I saw the go-parts inventory on ebay. I dont know if they will do custom drilling or anything but I can contact them to find out.
Old 10th July 2018, 10:23 PM   #12
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
GoodComponent and LandFal dont do these services. It's a simple service if you have a drill. Stay alert with workshops that do this service in CNC machine, very expensive.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 10th July 2018, 11:02 PM   #13
kevinkr's Avatar
Chassis service?
Originally Posted by rayma View Post
Will they do holes, cutouts, etc?
They can arrange for local machining if you need it.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 11th July 2018, 01:31 AM   #14
Then that defeats the whole purpose here.
Even if I did have access to a CNC machine, I would have to bust the wooden frame apart to route it properly anyways if they didnt do this service prior to manufacture.
thanks anyways.
Old 11th July 2018, 03:42 AM   #15
Trajan is offline Trajan  United States
A Hammond case and some Greenlee punches may be easier to use than you think. The punches will let you build multiple cases. Get some graph paper (or CAD if you can) and center punch the holes. Drill and use the Greenlee punch. You will be shocked how nice it can turn out.
Old 11th July 2018, 04:14 AM   #16
kevinkr's Avatar
Chassis service?
This is what I used to do, it's not hard. Here is an example of an amplifier I built 14 years ago. I've gotten better at it, but I was not awfully good at it to start.
Old 11th July 2018, 11:45 AM   #17
But this also requires you to have somewhat of a workshop to do this kind of work. Nice looking chassis though ;-)
Only thing I have is a kitchen table. That works ok for PCB assembly and some soldering like what I normally do.
But since I am renting the place fully furnished, if I destroy the kitchen table trying to do metal working, Things arnt going to end well with my landlord.
This is one of many reasons why I am avoiding doing the chassis. That and not having the tools.
There is also a piece to this that I havent discussed I dont think, the base I want wooden. not all metal. So that complicates things further, however I am sure I could find a wooden sign shop somewhere around here that could make the base for me.
But the tricky thing is, and the part that I hadnt mentioned is there would have to be routing involved in the front peice of wood that you look at. There is a VFD display and an IR recieve that I want to stick in that display, as well as potentiometer routing that needs to happen on each side of the display window. So basically making a "bezel" out of the front wood.
And, there needs to be a routed parameter around the display window so a piece of tinted lexan/plexiglass can fit in which adds contrast to the display, and "hides" everything.
Old 11th July 2018, 11:57 AM   #18
I guess for the wood I could probably use a dremel, I do own one of those. But I would need the routing bit set for it which lowes probably carries.
Old 11th July 2018, 12:09 PM   #19
JPS64 is offline JPS64  Germany
Chassis service?
Im doing the coffin using tailored sandwiched wooden: Buche Multiplexplatte Zuschnitt ⇒
Im thinking in the future to use foaam for raw cement coffin. The top and bottom plate are from Schaeffer AG, designed using the tool "Frontplatte Designer" (very simple to use): Schaeffer AG: Home
The overall price is not really cheap!
Attached two 3D views for 2A3 SET top plate.
JP
Old 11th July 2018, 12:22 PM   #20
Demonkleaner is offline Demonkleaner  United States
Demonkleaner's Avatar
I have one of these on the way for a new pre-amp. They offer polishing and different woods as well as other sizes. Aluminum top would punch very easily.
DIY Tube amplifier linestage preamplifier DAC audio chassis enclosure 3" Height | eBay
These pretzels are making me thirsty.--Kosmo
Chassis service?Hide this!Advertise here!
trade 5U chassis for 4U chassis + $70.00? ByronInPortland Swap Meet 3 27th June 2015 12:58 PM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 14th December 2007 11:41 PM
Chassis weinstro Solid State 10 24th January 2007 10:31 PM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 04:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 05:37 PM
