What should be 470nF input capacitors of my headphone amp seem to be 461nF for one channel and 492nF for the other channel. That is a deviation of 1,9% and 4.6%.
I measured the values of the capacitors already soldered on the board but without active components.
Are these errors to be expected because I measured them in the circuit?
And, would this be audible?
Or are these value errors a property of capacitors in general?
Cor
Cor
Haha you're probably right.If you have more than 2 of the beforementionned capacitors you could have measured / matched them before soldering them in, otherwise I agree on the tolerences quoted by Mooly. If yiu can hear it, you're in trouble
At first I was afraid I overheated one of the capacitors while soldering it in. It did not go as fast as I would like.
So I thought maybe the value could change because of the prolonged high temperature. And therefor I measured them while in circuit.
