Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
where to get an 6u8 63V CAP (ex philips 035GV)
Old 23rd June 2018, 08:01 PM   #1
artificialmustaches is offline artificialmustaches
Default where to get an 6u8 63V CAP (ex philips 035GV)
Hi, my LK1 Linn has the "disco light" issue -intermittent led in the front board, and the unit sometime quits to function. the manual's cure is "C12 on control board faulty Replace C12 Linn part no: CAP 022". C12 is an old philips 035GV 6u8 63V CAP. As on Ebay i couldn't find it, do you have any idea, or link, or new brand that i could buy to replace it? Thank you!
Old 23rd June 2018, 08:23 PM   #2
silasmellor is offline silasmellor  Denmark
Radial 6.8 uF 63 VDC Aluminium Electrolytic Capacitors - Leaded | Mouser Denmark
Take your pick, just make sure the dimensions fit the PCB.
Old 23rd June 2018, 09:18 PM   #3
thanks for the reply, and for the help. This is actually the one i've to change, it has a whitish drop of paint on top, and it's located close to c13; it fits a Linn LK1 pre-amp, probably it's the main cause of the fault of the unit Click the image to open in full size.
Old 23rd June 2018, 09:22 PM   #4
IMG 1155 — imgbb.com
Old 23rd June 2018, 09:42 PM   #5
I've found this, maybe it could work? 50x 6,8mF / 63V Elko 105degC 5x11mm 6,8uF | eBay
Old 24th June 2018, 11:22 AM   #6
Do you need 50? If mouser is impractical, I would see if a local electronics store might have some, or could get hold of them.
If the values are right I would only make sure that the width is correct for the pcb. I cannot judge that from a picture like the one you sent, but luckily it is one of the specifications you can read off the product pages.
Old 24th June 2018, 01:02 PM   #7
Thanks again: yes, i agree, but it's a matter of few euros anyway, and i can use some others recapping some identical cap on the main and on the control board. BTW this cap is 11mm x5 mm; with 2mm that is the distance fom pin to pin. And it seems compatible with the one i've to replace...
Old 25th June 2018, 04:13 AM   #8
davidsrsb is offline davidsrsb  Malaysia
Is the value critical, C12 is on the microcontroller Reset? A 10uF will work in most circuits.
where to get an 6u8 63V CAP (ex philips 035GV)Hide this!Advertise here!
Magnavox CDB-473 (with Philips TDA-1541 DAC) and CDB-610 (Philips TDA-1543 DAC) john65b Swap Meet 2 15th December 2015 01:37 AM
Philips RT8 Philips Ribbon Tweeters For Sale Monte Verdi Swap Meet 0 11th September 2013 06:23 PM
Philips CDM4/36 (new) and Philips CDM3 DAC2011 DIY HiFi Supply 7 7th April 2013 09:43 PM
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
