Dact stepped attenuator distortion?
I need to make a high precision low reactance variable resistor divider and normal potentiometers do not have ultra low tolerance between channels so I am looking at stepped attenuators instead.
Only one seller seems to be making a PCB stepped attenuators which is something I'd like to use in order to reduce lead length.
DACT audio attenuators
The curious thing I found is that the quoted distortion is 0.0001% which should be about -120db. That seems rather high for a resistor. Anyone know what that's about?
