Op Amps good to have at home in your box
I use the LF412 a lot since I bought many cheap and they tested well in one of Cordell's publications.
I recently bought some TL074's since a quad is fantastic for perf board construction.
I see the LM324 getting slammed. Can someone recommend a good cheap bipolar input quad op amp?
4558's, TL071/72, NE5532 and 741's will let you experiment with most projects whether they be audio or not.
I have TL071/072, and NE5532/5534 in the parts box. That is enough for 99% of my projects.
I've used 741's when I was a child a long time ago, but not since then. They were wonderful for their time, but that time has long since gone.
For audio, I have never heard the slightest improvement over the 5532 / 5534 from any of the technically better op-amps, so I don't bother with them. Sometimes "new and improved" is merely new, and no worthwhile improvement is actually possible.
The only other type of op-amp I've occasionally found a need for was something with a MOSFET output stage that can swing all the way to its supply rails, like the old TLC272. There are a few oddball applications where you need that ability.
-Gnobuddy
Joined 2011
Here are some of the ones I've put into drawers. There are quite a few more lying around in their Mouser shipping bags, waiting to be scooped up and organized into some of those still empty slots.
oh pissoff, sendsome myway
hey LineUp,
Are you using the single opamp extra circ?
With single opamps:
132/4
604 @24V
5534
AD797
As Andrew T said
The dual only has access to the three standard in/out pins, whereas the single has all 6pins available.
The internal unity gain compensation of the dual makes it's electrical performance significantly different.
Paraphrasing 1:Corinthians 13:11 ,,, "When I was a child, I engineered like a child..."
I think that TI has put some extra goodness in their range of NE5534. Just sounds great.
I still like the LM4562 for a dual.
OPA2604 is another.
Unlike Mark, I keep my legged opamps on static free foam and sort by manufacturer -- I have not married Analog and Linear Tech yet, they remain celibate and in their own prophylactic enclosures.
LF412 and NE5532 suffice for most of the signal path portion of my audio work. But I go through more LM358 and LM324 than I do the other two - for all the support circuitry which is common to equipment which doesn't use op amps in the signal path. Also lots of LM311 and 339.
Just another Moderator
Joined 2003
I just checked your circuit. Your power supply is +/-10V. Even with +/-15V, OPA2604 performance is unacceptable. It needs higher rail to perform (that's why it is often lost in an op-amp rolling).
ADD:
And have you checked OP275? It's another underdog op-amp because it doesn't perform well in a conventional circuit.
Ah, I must not have carefully checked the datasheet! Thanks :) I haven't looked at the OP275.
Tony.
hey LineUp,
With single opamps:
132/4
604 @24V
5534
AD797
Yes, I can use the 'extra pins'.
For example NE5534and unity gain, there is a cap 22pF to add.
Also can use 2 pins to adjust offset.
There are 2 reasons why I fancy single op amps.
1. The easier design of pcb. With dual op amp the card get 'crowded'. While I can have more space with two single op amps.
2. The maximal power. Two in a dual gives only half the power for each. The single op will run cooler.
ADD:
There is at least one thing that speaks for OP275.
Power supply can be max +/-22 Volt.
The same goes for NE5534.
Many op amps are restricted to +/-18V.
For example LME49710 is recommend to run at +/-17 Volt.
OPA604 can take +/-25 Volt. Absolute max.
It is unusual.
-Gnobuddy
Ain't that the truth. For low gain, low noise circuits, the 5532 does it all except for low offset. It behaves as a voltage follower with no fussing. It's low noise. It does not mess with the sound.
I like to DC cascade circuits as much as possible. OPA2134 is limited as a follower but works fine as an inverter. I cascade inverting circuits; 2134 goes in front, then 5532. In practice this works great and yields acceptable offset (less than 20 mV) without optimizing DC parameters.
