Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Budget audiophile speaker cables
Old 3rd July 2018, 12:21 AM   #211
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Originally Posted by DF96 View Post
To repeat myself, the designer would have already taken this into account. You are then adding extra resistance which he did not take into account.
Most 'consumer' speakers are supplied with fig8 flex with less copper than the coax.
There is no need to terminate both ends.
In practice I find it is indeed beneficial.
I cannot comment on what you think you hear.
I know what I hear, even if you do not.
No, I meant Zobel network. It is this which swamps any capacitive load imposed by an unterminated cable. An output inductor is another method for achieving a similar goal.
Uh huh, so how does a shunt RC Zobel 'swamp cable capacitance' ?.
Yes, and possibly more successful than braiding - although perhaps not quite as pretty.
Who who cares about 'pretty'.....coax routes perfectly well and is inconspicuous, not so for so many so called 'audiophile' cables.
Dan.
Old 3rd July 2018, 09:52 AM   #212
DF96 is offline DF96  England
You can assume that such speakers make no attempt at faithful sound reproduction so are outside the scope of this discussion.
By imposing a low resistance in parallel with the cable capacitance. This ensures that the phase of the load cannot stray too far from 'in phase' (i.e. resistive) at least in the frequency range of interest (typically 100kHz to a few MHz).
Old 3rd July 2018, 06:41 PM   #213
mchambin is offline mchambin  France
With best electrolytic capacitors as discussed in a neighbor thread, serially hooked to coax speaker cables at both ends, no doubt you will reach nirvana.
Transistor junction temperature is not transistor case temperature.
Old 3rd July 2018, 10:11 PM   #214
Pygmy is offline Pygmy  Netherlands
So eh, as this is still "budget audiophile".. I have to say I really am enjoying reading these discussions, but I still think my 42 year old ears won't be able to spot the difference between cables with and without certain pigment added ;-)
A funny side story - I was on holiday with my kids, my brother and his kids, and my parents in France 2 years ago, and at one point my brother commented on the really loud noise the crickets were making. (It really was deafening)
To which my parents replied "what noise?"...
To them it was perfectly quiet there :-)
Age really is a very important factor - do find out the age of the people you're discussing audio with :-)
Old 4th July 2018, 03:52 PM   #215
tapestryofsound is offline tapestryofsound  Scotland
Originally Posted by nigelwright7557 View Post
The only things in a cable that can affect sound are resistance, inductance and capacitance.
Resistance will reduce the sound level depending on just how much resistance and length of cable there is.
Inductance will reduce top end.
Capacitance will reduce top end.
I just use 13 amp stranded mains cable which is good at all three and have had no problems in 40 years.
Thank you for that Nigel, I think I will have a crack at using mains cable on my next build.
On my last build, I used automobile stranded loom wire, because like me, it was cheap. Made a pair of 4 strand braids - 2 pos - 2 neg, and together with fit for purpose banana plugs, ended up with two 10ft lengths for 20 total. That's 1 per ft. I have nothing to compare it to, but it seemed to work very well as speaker cable.
tapestryofsound
Budget audiophile speaker cablesHide this!Advertise here!
Budget audiophile amp? (or best cheap dedicated amp) solid7 Class D 25 21st April 2018 03:07 PM
budget audiophile amp suggestions? kcducttaper Solid State 9 16th October 2017 11:39 AM
ssabripo's DIY Speaker cables Tutorial (cat5e based): Audiophile wires on the cheap! ssabripo Everything Else 1 26th October 2006 02:32 PM
Designs? L18 + RS28/NC D25 For Budget Audiophile setup? demon2091tb Multi-Way 5 27th November 2005 08:05 PM
Budget cables? bobhayes Multi-Way 41 6th September 2004 09:15 PM
