Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Diode suggestion
Diode suggestion
Old 14th May 2018, 03:30 AM   #1
ian33 is offline ian33
Default Diode suggestion
I am trying to used IRGP4066 in place of IRGP4066D.
The problem is the D version has a built in diode and the other one does not.
Any suggestion on a diode i can used?
https://www.infineon.com/dgdl/irgp40...535655feed2454
https://www.infineon.com/dgdl/irgp40...535656073f2456
Old 16th May 2018, 12:22 PM   #2
Look like such a diode does not exist in a stand alone package.
Old 16th May 2018, 01:38 PM   #3
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Diode suggestion
parametric search results
Diode suggestionHide this!Advertise here!
diode rectifier suggestion for power supply necplusultra Power Supplies 1 25th January 2011 10:29 PM
Mounting a small signal diode on heatsink - need suggestion IG81 Solid State 14 3rd November 2009 04:12 PM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Suggestion of good bridge diode for A2 Alvin Pass Labs 3 28th May 2005 12:35 PM
