Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th April 2004, 05:20 PM   #1
wcorten is offline wcorten  Belgium
Default determine core, windings and L for choke in SMPS
Hi all,
I`m creating an SMPS that will convert 12Vdc to +-30Vdc.
Now I found all previous discussion concerning this kind of SMPS but I miss an explanation on how to calculate the chokes that ar e placed in series with the input and the chokes that are placed in the outputs.
I want to know what kind of core-size I need. (I will use torroid ferrite)
and how many windings or inductance the coil needs to have.
(switching frequency is 50kHz and output current is 6amps per rail)
At the input the choke is needed to filter out the pulses coming from the SMPS to the source supply and on the outputs the chokes are needed for a better DC with lower ripple. So basicly two times for energy storage. When it comes to capacitors it is easy, take as much C as you have, the more the better, is this the same case for the L or is the C-L combination important ?
Thanks for helping me out.
Plate choke material, why to use amorphous core? noyan Tubes / Valves 5 7th July 2008 12:25 PM
inductor/choke/air core/ferrite core. . . same thing? poolorpond Pass Labs 24 29th March 2008 10:55 PM
What size core for choke? Prune Parts 27 26th September 2004 09:04 AM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 04:15 AM
DIY E-I Core Filter Choke, how? JojoD818 Solid State 3 19th February 2004 04:30 PM
Page generated in 0.06000 seconds (65.46% PHP - 34.54% MySQL) with 10 queries
