Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
AD797 schematic
AD797 schematic
Old 16th April 2018, 03:04 AM   #11
jcarr is offline jcarr  United States
I believe that Q18 and Q19 are a bootstrap to keep the VCe of Q17 constant, regardless of signal level.
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 16th April 2018, 01:27 PM   #12
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
They bootstrap all the pairs of devices in the stage, in an ordinary circuit they would be the Vas devices and the voltage gain would be at best a few 100's of thousand's. This way what would be the Vas error voltage becomes a common mode error and a single gain stage achieves >5-10Meg. The input still sees the current burden of the output buffer as a differential error so it had to be a triple darlington with cascode from the output voltage.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 16th April 2018, 02:53 PM   #13
tomchr is offline tomchr  Canada
tomchr's Avatar
Ah. Very cool. Thanks.
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 16th April 2018, 05:20 PM   #14
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
i had this crazy idea of cascading two chips for more gain but i do not need the current gain of both chips. so i was looking at where i might access just the voltage gain stage.
thanks
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 16th April 2018, 06:01 PM   #15
thanks
The other side of the gain stage, (at R3, the opposite sense of where C2 is connected) is pin 8 on the IC. This would be the output unbuffered. I have heard folks put a resistor to ground here and use the part open-loop. Stuff like this needs some care and I have not tried any of it. If you can I would use John's (jcx) LTSPICE files and play around. For this the schematic here gives you all the info you need, some decent discrete models with around 600 MHz ft should be OK.
Your best bet in general would be to research the various composite amplifier schemes, there are lots of ways to skin that cat.
Old 23rd May 2018, 02:09 PM   #16
FritzS is offline FritzS  Austria
Send a message via MSN to FritzS
another discussion about AD797
Headphone Amp - AD797 compensation, distortion cancellation caps
Fritz AKG K872, K812, Q701, K701, K550, K271 MKII, Denon AH-D7000; GSP green SOLO, WNA MK II; Marantz SA7001 KI, Philips CD650; Revox B790, Goldring G1042; GSP green Reflex; sold Sennheiser HD600; as guest AKG K1000
AD797 schematicHide this!Advertise here!
AD797 and other ICs cygnus x1 Swap Meet 3 1st August 2015 01:27 PM
AD797/AD811 circuit schematic question TB Chip Amps 4 31st March 2014 03:43 AM
ad797 vs ? for i/v? PreSapian Digital Line Level 6 20th December 2013 02:10 AM
Where can I get an AD797 Op-Amp? xanduy Swap Meet 4 29th March 2004 07:06 AM
Ad797 audioPT Parts 12 31st October 2003 09:07 PM
