Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th April 2004, 06:58 PM   #1
Send a message via AIM to eRiCdWoNg
Default Help, light corrosion on PC board
Alright I got some components that have probably gotten wet before. Some of them are car audio components and another is a mixer board. Anyway I'm having trouble with the car audio EQ/crossover unit (audio control EQX series II). Every once in a while there will be a loud buzz that goes thru the woofers and right channel. I took the unit apart and found theres light corrosion on the circuit board. Theres nothing thats badly corroded, just some light surface corosion. I believe this corrosion is why theres some funny noises coming through. Heres a pic. Is there anything I can do about this?
Old 12th April 2004, 04:52 AM   #2
cogsncogs's Avatar
Thumbs up flux remover
Hi
A good flux remover should do the trick, and some wooden cotton tipped cleaning sticks. Parts Express has what you need:
http://www.partsexpress.com/pe/pshow...number=341-324
In a pinch you could try isopropyl alcohol 90-94% the kind used for injections etc. Not the rubbing alcohol stuff! Rat Shack sells the cleaning sticks. Just be sure the board is COMPLETELY DRY before powering up! Also don't drown the board in alcohol! You don't want to get alcohol soaking/wicking into the electrolytic capacitors. Remember alcohol is VERY flammable!
Wayne
Old 12th April 2004, 06:39 AM   #3
Thanks for the reply. I was also thinking what about other solvents such as denatured alcohol, acetone or lacquer thinner? I have all 3 of those at my disposal now, but no isopropyl. Do you think cleaning off the crud on the circuit board will fix my problem? Thanks.
Old 12th April 2004, 08:33 AM   #4
cogsncogs's Avatar
Thumbs down acetone!
NO!
None of the above is safe to use on plastics. Especialy acetone! That stuff dissolves plastic! Isopropyl alcohol is available at any drug store, eg Rite Aid, Wal-Mart etc. for under a dollar. Just make sure it's the 90% to 94% stuff. Not rubbing alcohol which is 70% or less and contains glycerin.
Well can't say fer sure just by looking at your pix. It looks like it's had something spilled on it. That loud buzz could be caused by a bad soldier joint, intermittent ground, bad switch-control or any number of things.
Cheers
Wayne
Old 18th April 2004, 04:29 PM   #5
I cleaned it up, so far so good, no funny noises. That might have done the trick, yay!
However I have another problem, on my 2nd unit one of the RCA connections is loose. I know which one it is, I tried to resolder it but it didnt help anything. I may try to remove it altogether then reinstall.
Best way to clean corrosion like this? 454Casull Everything Else 1 4th June 2009 02:37 AM
substance on board, corrosion jol50 Car Audio 37 31st December 2007 02:31 AM
I need 365v to power a light board?How can i get that? alapimba Power Supplies 7 4th February 2005 05:03 PM
silver corrosion eduard Tubes / Valves 17 26th July 2003 12:25 AM
Page generated in 0.08933 seconds (73.34% PHP - 26.66% MySQL) with 10 queries
