| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
given that i have a transformer with dual 14V AC secondaries, .. i want to obtain +/- 15 V DC , and also employ some kind of regulation..
question, .. if i use the PS schematic here (http://sound.westhost.com/project05.htm), can i safely ground the center tap. else, . . would it make more sense to use a circuit such as http://www.elfrad.net/Pics/pwrsup.gif thanks
"Any fool can know. The point is to understand" - Albert Einstein |
#2 |
Since you have a transformer with two secondaries, it's better to use the second circuit from the elfrad.com site. The first circuit is really only "half-wave" because it employs only two rectifier diodes, and you will have more ripple before the regulator. It should be used only when you have a single-primary transformer without a center tap.
-Ti |
#3 | |
Later BZ
What ever makes the tunes flow |
#4 |
secondaries on your xformer need to be more than 15 to achieve a stable 15 v from a 15v vreg..... and you'll lose some in your filter
Brad |
#5 | |
thanks for the posts so far.
good point, .. i was wondering about that , .. but wouldn't 14V AC rectified yield more than 14V DC to give me some headroom?? OTOH, ..this is for a line stage suply , .. and my opamps can also handle 12V, .. so I could just plug in the appropriate 7812/7912 regulators instead. thanks
#6 |
BR1 (Bridge Rectifier) can drop up from .7 to 1.2 volts... so watch that
make sure you have a stable power supply (like 16 volts for a LM7812 etc...) to get a clean power out of the reg.
Brad |
#7 | |
thanks, .. that makes sense
#8 |
The 14 vac secondarys will give you 14 * 1.414 = 19.8 vdc at no load into the regulator. The regulator will need about 3 volts or so to work. Ya, it's a little close. If you can work at 12 vdc I'd do it. That will be OK.
It realy depends on how much current you need. If only a few milliamps are needed then 15 volts might be OK. Besides the chip regulators are cheep and easy to change if you want to try it. Later BZ
#9 | |
For example, the Telema/Amveco toroidal transformer I used for my recent headphone amp project is spec'ed for 15-0-15 output at 117V input, but I measured over 22.5V DC after the rectifier with only 115V AC. -Ti |
#10 |
FYI, .. application notes
this rectifier module built to accept secondary input from a variety of trannys, perhaps via a molex or XLR connector. sometime in the near or distant future, .. i'll be using the setup to try out a bunch of projects such as 1. buffered (BUF634) preamp 2. buffered (BUF634) preamp driving a DRV-134 line driver to split phase on my tube amp 3. BUF634 driving edcor line trannys to split phase on my push pull tube amp 4. maybe a gainclone, .. although those may require different values of filter caps for optimum performance. right now, all i have in my parts bins are a huge EI 15V dual secondary and a cute dual 14V x 400mA EI transformer (which is what I wanted to use for a line amp PS) I'll play around and hopefully something will work out
| simple power supply schematics | getafix | Chip Amps | 8 | 12th October 2007 09:41 AM |
| Cmoy power supply simple question | wiredmonkey | Chip Amps | 2 | 17th July 2007 12:44 AM |
| simple bipolar power supply | BodomChild | Power Supplies | 4 | 12th July 2006 07:25 AM |
| Simple toroidal power supply assembly question | wigginjs | Solid State | 0 | 2nd July 2004 05:41 PM |
| simple power supply question..... | Luke | Pass Labs | 5 | 31st March 2004 06:22 AM |
| Page generated in 0.11094 seconds (78.59% PHP - 21.41% MySQL) with 10 queries |
