Toroidal transformer mounting & orientation - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th April 2004, 12:32 PM   #1
Question Toroidal transformer mounting & orientation
G'day All...
I am in the proces of building a 125W/8R dual mono solid state power amp and have a couple of questions relating to the power supply - namely the placement of the 2 x 300VA toroidal transformers.
1. What effect will mounting one toroid on top of the other have? Should this be done?
2. What effect will mounting one toroid on top of the other with one upside down have? Should this be done? I can imagine the magnetic flux generated by both would cancel out - providing a severly under-rated output worst case? Or would it be beneficial for some reason?
4. Will mounting the toroids vertically have an adverse effect?
3. What is the minimum distance from a 300VA toroid that any part of the amp PCB can be placed? I would also assume that one would place the output stage of the power amp closer to the toroid rather than the input stage?
I guess I should say 'hello all' now, i've just joined this forum and from what i've seen so far it looks very informative. I look forward to getting to know those that I will.
Thanks people.
Nic.
Orientation and Horizontal Mounting SY Tubes / Valves 35 29th August 2016 01:37 PM
Toroidal transformers mounting akis Power Supplies 6 24th August 2009 04:35 PM
toroidal transformer mounting kit digitalabyss Parts 0 30th April 2009 10:45 PM
Transformer orientation Skorpio Pass Labs 5 12th May 2006 02:25 AM
EI transformer orientation ultrachrome Power Supplies 3 28th March 2005 05:11 PM
Copyright 1999-2017 diyAudio
