Sadly, there's no true alternative to these jfet. It's been discussed here: Replacement For Toshiba 2SK170/2SJ74
Since you're in Hong Kong, there's a reliable seller selling pairs of matched 2sk170/2sj74: FET Audio | Hi-End Audio Projects
Or, just order new revision of the Dynalo. All current production parts, without the hassle of those discontinued and expensive parts.
Any schematic for the new version Dynalo??
Yes, just ground the negative input for unbalanced input
Thanks. BTW, do you know any website which provides good documentation of this amp?
The that 340 is made of BJT, not jfet. The new dynalo is also a balanced design with a low input impedance. They're really very different amps.
What's the difference on sounding between BJT and JFET'
You are correct. The THAT chips are BJT, not JFET. However you can use JFETs as a few have been built using an adapter PCB for the toshiba transistors you mentioned.
While the toshiba transistors are no longer available, couldn't you use the lsk170/lsj74 from the diyaudio store?
Most of the information is at head-case
Btw, the dynalo is a nice sounding amp (I've got one) but it's not something worth spending 100$ in jfet.
If I wanted an amp in the same class today, I would rather build a ckiii with BJT input: https://www.amb.org/audio/ck2/
The beta22 is a big powerful amp. Great if you have hard to drive headphones. If you have easier cans to drive, I'm not sure there's any real benefit.
Honestly, all my headamps are gathering dust since I built a small one based on opamps in the feedback loop of one another.
Btw, I found over the years that most of the differences between competent amps were absolutely minor. I'd rather spend money on headphones. They do make a big difference.
- Design & Build
- Parts
- Dynalo parts replacement
