Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th April 2004, 08:34 PM   #1
colin.hepburn2's Avatar
Default Diy UV exposure unit Lamp info Pleas
Hi All
I am a bout to make a UV exposure unit to make my PCB and not sure about the type of lamp to use Can some one let me have info on this I was thinking of the black light uv as used in Disco’s size 300mm 15 watt types
thanks
Colin
Colin
The Blues Man
Old 8th April 2004, 08:48 PM   #2
you may use
F15T8-BL from general electric work well an is not dangerours for your eyes
Old 8th April 2004, 09:17 PM   #3
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb UV lamp
Hi, In my unit are four Philips type TL8W/05 #5F.
Old 8th April 2004, 09:28 PM   #4
Default Uv Lamps
Thank's to All
I will check those lamps out
cheers
Colin
Colin
The Blues Man
Old 8th April 2004, 09:29 PM   #5
audioPT is offline audioPT  Portugal
Check out my uv box:
The old one:
Old 8th April 2004, 10:50 PM   #6
Default Uv Lamps
Hi Audio PT
You mast have put some time in to that look’s the biz what lamps do you have in
I was just thinking of some sort of basic unit
Colin
Colin
The Blues Man
Old 9th April 2004, 12:09 AM   #7
Default Uv Lamps
Hi all
Found a lamp strait UK mains voltage saves on ballast fittings would two of theas work ok for basic box? Or this one Code L49AF
on this link
http://www.maplin.co.uk/
http://www.maplin.co.uk/media/largeimages/31628i0.jpg
Colin
Colin
The Blues Man
Old 18th April 2004, 07:48 PM   #8
Default UV Lamps
Hi All
I just got the UV lamps 4 Philips TL15w/05 but would like advice on the ballast units and wiring for the four lamps
Colin
Colin
The Blues Man
History and info's about Goto Unit drivers and horns angeloitacare Multi-Way 11 24th July 2008 06:28 PM
PSU Rebuild Help Pleas colin.hepburn2 Tubes / Valves 7 1st June 2006 12:10 PM
Test Lamp as a fuse info??? Zero Cool Solid State 3 23rd December 2005 02:09 PM
Audiopoetry - pleas add Esra Yeknom Everything Else 0 20th January 2004 01:57 PM
Pleas Help!!! PSU for LM3886? Christian Solid State 7 6th August 2002 01:49 AM
Page generated in 0.09745 seconds (78.73% PHP - 21.27% MySQL) with 10 queries
