I've done it by connecting a PNP transistor as a CCS in place of "R1" (the resistor from +V to pin 7). This way it charges linearly (dv/dt = C * I... dv/dt = rate of voltage change) by the CCS and R2 and discharges just through R2 (the CCS' current is shunted through pin 7).
By varying base current to the CCS you can get an extreme duty cycle.
Tim
Tim
Hi Ricky,
Another way to do it is use a resistor in series with a diode (i.e. a 1N4148) from the output to the cap to charge the cap, this sets the fixed on time. Use another (variable) resistor from the discharge pin to the cap to discharge the cap and set the off time. This works best with CMOS 555’s.
Cheers
Cheers
- Design & Build
- Parts
- Pulse Generator Schems?
