| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I asked a question previously about how a sub plate amp affects the load seen by the satalites' amp. The reply was that the high level inputs are buffered so the amp essentially sees no extra load.
Well Ive been experimenting with a Pyle car crossover/eq with a pair of Linkwitz H baffle subs. They work remarkably well but Ive only been using GC amps at low volumn. The Pyle is connected in parallel with the main speakers and dont seem to create problems with the amp. Im now wondering if Ive just been lucky - is this not a good idea? Are the high level inputs on these things usually buffered also? Id really like to use this crossover setup with my Magnepans and hence, a 200watt amp with the crossover in parallel with the Maggies. Will it destroy the crossover or raise hell on anything else? I will eventually get a proper crossover/eq (dbx, berhinger etc) but this is cheap and fun. thx amt |
| sub amp question for MJK open baffle | pforeman | Full Range | 7 | 15th May 2009 07:19 PM |
| A MTMvTMM? & A Open Baffle Question | Ben Reginato | Multi-Way | 1 | 18th October 2006 12:06 PM |
| Open-baffle design question | Aengus | Multi-Way | 6 | 17th May 2006 06:37 PM |
| Open Baffle vs Box Speaker Question | Robert McLean | Full Range | 23 | 24th May 2005 09:54 PM |
| Electrostatic HF, Open Baffle LF Question | mrfeedback | Multi-Way | 1 | 21st August 2002 02:40 AM |
| Page generated in 0.35067 seconds (13.31% PHP - 86.69% MySQL) with 10 queries |
