Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th April 2004, 01:18 PM   #1
Default is it safe for the caps...
is it safe for the caps rated 1000uF/50V to work on 48V. I have transformer with center tapped 30V secondaries 0.5 A. Right after the diode bridge I have about 32V but after connecting caps voltage goes to about 48V. I tried it once. No big boom, smoke or anything. Caps were sitting intact but it worked maybe a ten seconds and unloaded so can't tell more. It's supposed to be a part of power supply for tube in valve buffered LM3875 amp.
Is it gonna work or I have to order different caps ?
Anyway it would be cheaper than new transformer.
thanks
Old 5th April 2004, 01:30 PM   #2
analog_sa's Avatar
It will probably work fine for months but it's not a good long term solution. If the mains fluctuates 10% you'll exceed the caps rating. They will certainly fail faster, especially if the the ambient temperature is on the warm side.
Old 5th April 2004, 01:39 PM   #3
i'm not pretending to be a professional on the matter but i did actually ask iee teacher in elec engineering about something similar, and he said it's fine to run the capacitors within 10% over their limit but you are taking a risk of increased heat and hence shortened lifetime, just my understanding
Old 5th April 2004, 02:00 PM   #4
any ways to lower the voltage to be safe for the caps
what about resistor across the cap ?
Old 5th April 2004, 02:07 PM   #5
HDTVman is offline HDTVman  United States
Should not be a problem. As soon as you put a load on that PS the voltage will drop a little. It depends on the load current but right now the caps are charged to peak and nothing is discharging them between peaks of the rectified AC. Most of the time short term overvoltage by 10% or so is not a problem as caps are designed to work at rated voltage.
Later BZ
What ever makes the tunes flow
Old 5th April 2004, 02:11 PM   #6
thanks guys
It makes me feel better and my caps too.
Old 5th April 2004, 02:31 PM   #7
ClassD is offline ClassD  Australia
ClassD's Avatar
Send a message via MSN to ClassD
Running a cap that close to it's rating is not a very good idea. It would be much safer if you payed the extra couple of dollars for 63V caps. This is from one of National's datasheets:
The capacitor’s voltage rating should be at last 1.5
times greater than the output voltage. For a 10V regulator,
a rating of at least 15V or more is recommended.
This is probably taking it a bit far, but I think 63V caps would be the way to go.
Old 7th April 2004, 08:51 AM   #8
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
The ambient temperature is a major factor, since if the cap fails at all, it will be through leakage and overheating.
In other words, you can get away with more in a cold place.
Old 7th April 2004, 10:16 AM   #9
Jennice is offline Jennice  Denmark
classD,
I they refer to a regulator with e 10V output. However, if they mean that the regulator is SUPPLIED from 10VDC, there's no point in this margin.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 7th April 2004, 11:40 AM   #10
ClassD's Avatar
But there is no guarentee that the mains voltage will be nice and constant. Watching the voltage history on the UPS systems at work there is quite a large variation. The caps won't fail straight away, but as dhaen says - running them at high voltage does derate the lifespan.
Are these caps safe? Sonusthree Power Supplies 12 13th April 2007 01:01 PM
Is it safe???? mikee55 Solid State 4 31st August 2006 10:17 AM
Safe Practices bzdang Chip Amps 2 10th July 2004 07:11 PM
Hakko 936 - ESD safe vs. non-ESD safe KT Parts 2 20th June 2004 03:58 AM
Page generated in 0.10772 seconds (78.99% PHP - 21.01% MySQL) with 10 queries
