diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Balanced Signal Levels- voltages?? (http://www.diyaudio.com/forums/parts/31589-balanced-signal-levels-voltages.html)
lgreen 4th April 2004 04:51 PM
What voltages does a CD player with a balanced output provide on that output? Isn't there some kind of standard for this?
markp 4th April 2004 04:56 PM
Unbalanced output is 2 volts max as a standard for CD player output. I would not be surprised if balanced out was 2 volts peak to peak. Not sure though.
Jan Dupont 5th April 2004 07:47 PM
Some excotic CD players have up to 8V pp ;)
markp 6th April 2004 02:00 PM
Yes, but the standard spec is 2 volts max.
moamps 6th April 2004 02:13 PM
Re: Balanced Signal Levels- voltages??
professional CD-s have usually standard output (balanced output) level of +4dBm at 600ohms load. This level can be also internally adjustable.
markp 6th April 2004 03:22 PM
1.23 volts is +4dBm into 600 ohms.
http://www.raltron.com/cust/tools/voltage_to_dbm.asp
Resources saved on this page: MySQL 18.75%
