Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Output transformer layering problem
Old 17th December 2017, 07:38 PM   #21
euro21 is offline euro21  Hungary
Read this.
Power Systems Design (PSD) Information to Power Your Designs
Z-winding is a bit problematic, but worth it.
Old 17th December 2017, 08:40 PM   #22
50AE is offline 50AE  Bulgaria
Originally Posted by Elerion View Post
50AE, thank you once again.
About interlayer capacitance, primary sections are usually several layers high. In this case, one layer goes in one direction, and the next comes back, so it is not possible to follow the same direction as the secondary, as you said. Correct?
Euro21 mentioned Z-winding for your case. An even better thing is the vertical sectioning, the best is bank winding.. But for a beginner, I don't recommend for you to go further than Z-winding .
Old 18th December 2017, 09:14 PM   #23
Elerion is offline Elerion  Spain
Until I feel confident, and manage to make some good PT and OPT, I'll use simple techniques. Step by step.
But thank you for all the tips.
Output transformer layering problemHide this!Advertise here!
Priboi (Surf :d) output transformer possible problem crazymechanic Tubes / Valves 5 11th April 2016 06:45 PM
Push Pull Output Transformer wiring problem cyl Tubes / Valves 8 25th April 2007 03:23 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
Not your average output transformer problem Turbo7MN Tubes / Valves 7 20th February 2006 04:52 PM
Baffles: Real Wood vs MDF vs Layering Monroe Multi-Way 19 14th April 2004 11:42 PM
